Fuel pressure regulator?
05-05-2010, 06:52 PM
Hey guys,
what's a good Fuel pressure regulator to replace the stock pump? If so any brands recommendable?
Thanks,
Heshan.
Cheated on my いたずらな女の子 and now I can't get enough of her..
05-05-2010, 07:14 PM
i use a sard 1 and no problems
05-05-2010, 07:20 PM
do you know where i could find one? i cant find it in ebay..
05-05-2010, 07:49 PM
this is where i got mine and my engine builder said these were best
http://www.tokyoseven.com/T7/product_inf...35df1c2b3a
05-05-2010, 08:11 PM
thanks GTAPEX.. which size did u use on your car? there're two in the given link.. its a bit pricy as well eh?
05-06-2010, 04:21 PM
anyone else with a suggestion with a replacement for the stock?
05-06-2010, 04:26 PM
why do you need a pressure regulator? Different types for different applications..
05-06-2010, 04:28 PM
I'm on a mission to replace the old parts with new parts but trying to replace with OEM or parts which will give same sort of performance.. not looking to go faster..
got anything for that? Smile
05-06-2010, 04:41 PM
Can you try refinishing the old fuel rail and regulator? There isn't really any performance to be gained in the regulator unless you plan on doing some very dirty oldschool tuning or boost. I would save those pennies to spend on something you'll really notice and enjoy later on.
The OEM regulator is nicely small and light. It fits perfectly on the fuelrail and gives exactly the right pressures and flows for normal 4A-GE's. Most aftermarket items seem to be built for airplanes.. To be honest, I would consider them mostly a downgrade due to their weight. Every regulator out there will work (just don't use a carby unit).
05-06-2010, 07:16 PM
When you mean refinish just clean it up and basically see if i can rebuild it? but i'm worried that with the weather over here if its on its last legs.. Our weather is a killer for cars and its OEM parts..
But I will take your word for it and try rebuilding it and keep the original as it is.
Can you help me with the injectors then? I found out in my last tuneup that one of them were not pressuring as same as the others.. what could be the telltale signs of these on a superficial level? can the engine miss a bit?
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 25,052 08-19-2018 12:08 PM
Last Post: AlexKTM
  4AGE Fuel Regulator Alex170984 6 12,277 02-24-2016 05:59 PM
Last Post: totta Crolla
  Oil Pressure Query Alex170984 2 6,370 12-11-2014 01:25 AM
Last Post: Alex170984
  Pressure gathering in fuel tank Apolan 9 18,235 05-18-2014 06:18 AM
Last Post: chenfon
  oil pressure high kawo 17 25,056 09-29-2013 12:06 PM
Last Post: allencr
