Fuel pressure regulator?
05-05-2010, 06:52 PM
Hey guys,
what's a good Fuel pressure regulator to replace the stock pump? If so any brands recommendable? Thanks, Heshan. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
05-05-2010, 07:14 PM
i use a sard 1 and no problems
05-05-2010, 07:20 PM
do you know where i could find one? i cant find it in ebay..
05-05-2010, 07:49 PM
this is where i got mine and my engine builder said these were best
http://www.tokyoseven.com/T7/product_inf...35df1c2b3a |
05-05-2010, 08:11 PM
thanks GTAPEX.. which size did u use on your car? there're two in the given link.. its a bit pricy as well eh?
05-06-2010, 04:21 PM
anyone else with a suggestion with a replacement for the stock?
05-06-2010, 04:26 PM
why do you need a pressure regulator? Different types for different applications..
05-06-2010, 04:28 PM
I'm on a mission to replace the old parts with new parts but trying to replace with OEM or parts which will give same sort of performance.. not looking to go faster..
got anything for that? ![]() Cheated on my いたずらな女の子 and now I can't get enough of her.. |
05-06-2010, 04:41 PM
Can you try refinishing the old fuel rail and regulator? There isn't really any performance to be gained in the regulator unless you plan on doing some very dirty oldschool tuning or boost. I would save those pennies to spend on something you'll really notice and enjoy later on.
The OEM regulator is nicely small and light. It fits perfectly on the fuelrail and gives exactly the right pressures and flows for normal 4A-GE's. Most aftermarket items seem to be built for airplanes.. To be honest, I would consider them mostly a downgrade due to their weight. Every regulator out there will work (just don't use a carby unit). A wheel to steer the front of the car A pedal to steer the rear |
05-06-2010, 07:16 PM
When you mean refinish just clean it up and basically see if i can rebuild it? but i'm worried that with the weather over here if its on its last legs.. Our weather is a killer for cars and its OEM parts..
But I will take your word for it and try rebuilding it and keep the original as it is. Can you help me with the injectors then? I found out in my last tuneup that one of them were not pressuring as same as the others.. what could be the telltale signs of these on a superficial level? can the engine miss a bit? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,825 |
4AGE Fuel Regulator | Alex170984 | 6 | 10,548 |
02-24-2016 05:59 PM Last Post: totta Crolla |
Oil Pressure Query | Alex170984 | 2 | 5,382 |
12-11-2014 01:25 AM Last Post: Alex170984 |
Pressure gathering in fuel tank | Apolan | 9 | 15,523 |
05-18-2014 06:18 AM Last Post: chenfon |
oil pressure high | kawo | 17 | 21,295 |
09-29-2013 12:06 PM Last Post: allencr |
