Fuel related issue?
07-30-2010, 03:50 AM
Fuel related issue?
I can only assume what I'm facing is a fuel related issue, but just want to get a second opinion.
The symptoms I'm facing are
- Hesitation at about the 2k mark when pulling away when cold
- Trouble starting the car (until 3rd turn of the key) when car is warm, in some/most cases after I've fuelled up
- on the odd occasion I get almost like a backfire pop from one of the ITBs
My first reaction is to change the fuel filter in case this is clogging up the works, but I also want to know if my lack of a charcoal canister could have any side effects that relate to this issue? I've recently changed the spark plugs and coil pack, so I don't think they're the issue, but I do need to check the timing at some point to see if that could be related,
Anything else I could check?
07-30-2010, 11:24 AM
Fuel related issue?
Throttle position sensor ?
Cold start ?
Do you need to give it throttle to get it to start on the third attempt ?
07-30-2010, 01:43 PM
Fuel related issue?
I don't believe it's the TPS as the EMS shows a reading for it. The car doesn't have a cold start injector, it's mapped to throw in more fuel when the engine is cold.
  PWR light issue and no brake fluid after winter storage magpie 10 3,876 05-25-2023 08:09 AM
  Fuel pump issue DJexor 11 6,569 04-29-2022 05:45 AM
  Clutch Issue Deaty 8 5,087 04-09-2021 10:26 PM
Last Post: Nakilad
  5th gear issue r.ave 1 3,113 03-14-2021 08:52 PM
  exhaust odor/idle MOT issue Ryo 7 8,415 07-15-2019 09:17 AM
Last Post: jondee86
