Fuel related issue?
07-30-2010, 03:50 AM
Fuel related issue?
I can only assume what I'm facing is a fuel related issue, but just want to get a second opinion.
The symptoms I'm facing are - Hesitation at about the 2k mark when pulling away when cold - Trouble starting the car (until 3rd turn of the key) when car is warm, in some/most cases after I've fuelled up - on the odd occasion I get almost like a backfire pop from one of the ITBs My first reaction is to change the fuel filter in case this is clogging up the works, but I also want to know if my lack of a charcoal canister could have any side effects that relate to this issue? I've recently changed the spark plugs and coil pack, so I don't think they're the issue, but I do need to check the timing at some point to see if that could be related, Anything else I could check? |
07-30-2010, 11:24 AM
Fuel related issue?
Throttle position sensor ?
Cold start ? Do you need to give it throttle to get it to start on the third attempt ? An analogue brain in a digital World |
07-30-2010, 01:43 PM
Fuel related issue?
I don't believe it's the TPS as the EMS shows a reading for it. The car doesn't have a cold start injector, it's mapped to throw in more fuel when the engine is cold.
PWR light issue and no brake fluid after winter storage | magpie | 10 | 2,738 |
Fuel pump issue | DJexor | 11 | 5,225 |
Clutch Issue | Deaty | 8 | 4,381 |
04-09-2021 10:26 PM Last Post: Nakilad |
5th gear issue | r.ave | 1 | 2,613 |
03-14-2021 08:52 PM Last Post: Ivan141 |
exhaust odor/idle MOT issue | Ryo | 7 | 7,344 |
