GAUGES - which?
02-07-2007, 07:48 PM
GAUGES - which?
Hi,
im buying gauges for oil temperature and oil pressure. Can anyone advise me which to get. I need precision, normal price and adequate styling (plain black (VDO-siemens like).
So im looking for Siemens-VDO gauges, but cant quite find a shop nearby. What are your opinions on theese?
Also found theese (EQUUS gauges):
http://www.iequus.com/products.php?category_id=100
Does anybody know what they are like?
Or perhaps if you have any other recomendations..
02-07-2007, 08:39 PM
GAUGES - which?
Equus are cheap crap, slightly less so are the simpler VDO offerings.. but I'm sure both will do fine, since you not driving a spaceship or something.
Most of the more expensive gauges stand out like a turd in a punchbowl on an ae86 dash, and I like the stock look personally.
02-08-2007, 07:58 PM
GAUGES - which?
Get Autometer
[Image: AEU86 AE86 - GAUGES - which?] http://www.jdmbits.com
02-08-2007, 08:22 PM
GAUGES - which?
Demon Tweeks are quite good for almost everything, they have guages in lots of styles and mounting pods, etc.
Look in te Motorsport Section.
http://www.demon-tweeks.co.uk/
02-09-2007, 01:37 AM
GAUGES - which?
nmwisima you are back, or did you find an internet conection it the states Big Grin Anyway, people i know that used autometer said its crap.. but then again probably anything is.. really. I suspect people have mounted sensors ackwardly and got fake readings.. i dont know.
02-09-2007, 11:46 AM
GAUGES - which?
No contest: fire up ebay and find yourself a set oil/pressure/temp gauges from an early 911. Simply the most beautifull gauges out there. Senders will be more expensive (maybe if you need to get them through porsche, but the guages themselves are fairly cheap 2nd hand.
02-09-2007, 01:27 PM
GAUGES - which?
Yes true, i've seen a couple of those on ebay. Beautiful items (look similar to Siemens VdO ones). But the problem as you said is that none of thos include senders.. i'll see..
02-09-2007, 03:09 PM
GAUGES - which?
They are VDO ones, but the quality ones. So thats explains the resemblence.
02-09-2007, 04:55 PM
GAUGES - which?
Or get original VDO's
If you like VDO you can also check for Steward Warner gauges.
Autometer are not crap.
p.s Yes I back from US but I m leaving again. Pics and comments on Wednesday.
02-09-2007, 05:25 PM
GAUGES - which?
I think Takumi has one of those
http://www.gaugeguys.com/Smiths/motorsport.htm
Vladimir
N/A for life...
  20v BT - which oil pump? Mylesmck 4 4,987 06-21-2022 04:51 PM
Last Post: pack
  Rim width. Which is best.... Dino86 5 8,836 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 10,187 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 6,462 02-15-2015 11:14 AM
Last Post: ditn
  which piston is this? ditn 10 15,033 07-04-2014 03:18 PM
