GOLDEN EAGLE VACUUM MANIFOLD
07-13-2008, 01:06 PM
just bought one of these to go with my itb setup, what way do i install the pipes to work the map sensor
07-13-2008, 01:09 PM
If you are on 20v itbs you will notice there is a vacuum nipple on each of them...take the vac lines from here into the vacuum collector. Or... you can tap nipples into the ITB adapter/manifold.
This was my old 4AGE setup..
[Image: AEU86 AE86 - GOLDEN EAGLE VACUUM MANIFOLD]
I didnt use the outlets on the ITBS - the vac was taken straight from the manifold...but you can see the places on the ITBS themselves (have the short runs of blocked vac pipe on them).
Use the one-way valve on the golden eagle item to go to the brake booster, and use another outlet for the map sensor.
Are you going to try and run a std ECU ? if not you dont especially need the map sensor as you'll be able to map on throttle position.
Hope that helps.
Regards Ian.
07-14-2008, 06:36 PM
yeah that's great tanx, no tryin to run megasquirt nearly have it wired. what were you running with?
  Smallport inlet manifold totta Crolla 6 3,745 01-17-2022 05:14 PM
  US-spec vacuum hard lines LordTD 2 5,262 04-27-2015 07:18 PM
Last Post: Project D
  4age blue top from MR2 same intake manifold? dinkers542 8 11,029 11-02-2014 05:24 PM
Last Post: ditn
  VALVE ASSY, VACUUM SWITCHING, what's this for ? Uzelac 10 15,202 11-22-2013 10:40 PM
Last Post: jondee86
  4AGTE turbo manifold questions daveskatesallday 3 5,171 08-13-2013 07:38 PM
Last Post: daveskatesallday
