Gnugfur of Norway! Viking power (56k, go learn russian)
01-02-2009, 10:59 PM
First part of the shipment from T3. waiting for it all to arrive before i do anything to the car. (Thanks Gia & Gabriel at T3)
[Image: AEU86 AE86 - Gnugfur of Norway! Viking p...n russian)]
New rims since the last pictures were taken.
Interior pic. (its the last thing that gets modified)
Got bored, strippet and repainted the inner screens on both front sides. Not a single sign of rust when i blasted it. =) (i'll try to remember taking pictures next time)
[IMG][Image: AEU86 AE86 - Gnugfur of Norway! Viking p...n russian)] [/IMG]
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
01-26-2009, 12:27 PM
a little update.
brakes has arrived.
Waiting for a enginebuild from CLK motorsports. Smile
1. AE92 MAP 4A-GZE engine reconditioned and modified to use in RWD turbo charge purpose come without exhaust manifold.
2. Small port 4A-GE intake manifold and throttle body modified to be use in RWD purpose.
3. RWD 4A-GE engine brackets installed so it will fit the AE86 engine cross member directly.
4. RWD 4A-GE water piping system with thermostat
5. 8.5” (212mm) flywheel
6. Reinforced 8.5” (212mm) clutch cover
7. Custom made wiring loom to fit RWD turbo charge purpose
8. Make the DLI rpm signal to run correctly on your AE86 Levin stock tachometer
9. 4A-GZE ECU system with all the electronic components (ECU, MAP sensor, DLI igniter, twin coil pack, relays, sensors etc) that need to run the engine
10. 4A-GZE injector
11. 4 wires oxygen sensor
12. 4A-G W bell housing
13. W series gear box with mounting and yoke
This should work, i'd recon.
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
02-11-2009, 07:12 PM
Hey mate if you need a hand to fit your new parts give me a call Thumbs up! don't have much else on at the moment haha
02-12-2009, 10:43 AM
Some cars look fantastic and you just cant tell why... Thumbs up! Thumbs up!
[Image: AEU86 AE86 - Gnugfur of Norway! Viking p...n russian)] http://www.jdmbits.com
02-12-2009, 12:26 PM
Good car Big Grin if you are done with it till july maybe u shud stop by and say hello on the Japmeet trackday? We hachis will pwned their ases!
Don´t Think About The Past,
Live In The Present And
Dream About Tomorrow
02-16-2009, 02:20 PM
hi, at work alot so i havent had the time to follow up.
My engine is almost completed, i just have to get the final transfer away wich is a bitch when trapped on a oilrig.
I've gotten alot more parts like Wilwood brakes and the rest of the suspension parts. So things are coming together.
I dont think i will be done with the car until july. I got alot planned and so little time to do it.
I will try to get more pictures up to you guys later on. The guys at CLK are most proffessional and have sendt me a tonnage of pictures of the engine build.
Cheerio,
Rob
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
02-18-2009, 12:18 AM
http://smg.photobucket.com/albums/v331/g...%20bilder/
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
02-18-2009, 12:36 AM
Hi
Where did you buy wilwood brake kit. Did you bought it as a kit?
Regards,
Isac
02-18-2009, 04:00 PM
awesome rims btw !
Money bar:
(0,-[=|1.000,-|========]12.000,-)
my goal: a AE86 Trueno Sprinter of my own.
02-18-2009, 09:57 PM
Crowfield Wrote:awesome rims btw !
Thanks. I got them custom made from Compomotive.
I bought the Wilwood brake kit from TechnoToy tuning. <3
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
  Hei from Adelaide South Australia via Bergen Norway Kid Karola 36 45,842 12-09-2011 04:29 PM
Last Post: Eircamae86
  Hello from Norway Rascal21 3 5,616 11-11-2008 12:18 PM
Last Post: Mux213
  Finally! Blue hatch owner from Norway. Syns 6 6,642 07-30-2007 02:07 AM
Last Post: Apolan
  New kid on the site..faz with pix(56k no no) faz 9 7,454 05-07-2007 08:25 AM
Last Post: joe69
  Hello from Norway :) (newb ae86 ownership Q's) MiRo 3 4,267 01-22-2007 06:38 PM
