11-08-2004, 03:56 PM
Euro spec Toyota Corolla GT (AE86)
First registration: 1987 VIN: JTC0AE8600239597 Engine: Rebuilt AE92 4A-GE (smallport) HKS valve springs T3 big-smallport adapter Simota filter Stock exhaust header, exhaust pipe and muffler Transmission: Stock gearbox JUN light flywheel Racing clutch plate (metal) T3 short throw shifter Suspension: APEX springs Koni red shocks Prothane bushings Interior: All stock (KingDragon seat waiting to be installed) Exterior: All stock Wheels: Front: 14 x 6.5 2-piece Work Equip 01 Rear: 14 x 7 2-piece Work Equip 01 Plans after that: Immediately fix rust (hatch, flares) Learn to drive a RWD car properly (debateable) Sort out suspension (not shure how yet), enhance driveability If bank account allows, fix interior Same as above, fix exterior |
11-08-2004, 04:25 PM
Nice.
Is the new engine MAP or AFM type? You will also need make/buy adapter to fit the RWD intake manifold on a small port engine. Drifting - best fun you can have in your car with your pants on! |
11-08-2004, 05:18 PM
Engine looks MAP red top so its a 7 rib right looks like one from 1989
11-08-2004, 05:53 PM
Engine is indeed MAP, 7 rib, high compression, small block, oil squirters ,etc.
It came off an automatic AE92, so it has had a relatively "civilised" life (so far ). ZaX --> you are right. The adaptor for the intake is in my budget. |
11-08-2004, 06:09 PM
You greek people have ae86 i always think that you drive your scooters
11-08-2004, 06:19 PM
Sometimes I wish I did
11-08-2004, 07:22 PM
I was in kreta 6years ago we lived at a farmers hotel in chania.
The food was great but not al the turist ihate countrys whit lots of turist infect the country |
11-09-2004, 12:06 AM
Dorito86 Wrote:Engine is indeed MAP, 7 rib, high compression, small block, oil squirters ,etc. Then you have the same engine like me. 7rib small port with MAP is very rare 100kw/140hp engine. Drifting - best fun you can have in your car with your pants on! |
12-03-2004, 03:51 PM
Finally an update on my engine swap.
The "new engine" was taken apart on Wednesday evening. Parts look to be in top condition. No obvious play in the valves, cams or crankshaft. Yesterday was "parts cleaning day"and today morning they will take a chemical bath and undergo some machining work (don't know the english technical term). I have already ordered the port adapter from T3 and I am currently looking for performance springs and retainers. Any ideas? Pictures coming soon, but don't expect too much detail, as closeups are very blurry |
12-03-2004, 03:58 PM
Retainers are probably cheapest from a toyota yaris (look it up in the club4ag tech section for the engine code and part nr's.). Those are inner-shim buckets.
Valve springs are available from some aftermarket cam manufacturers I think (maybe catcams or Kent?). FABRICA MI DIEM, PVNC! |
Full restoration... | Blade1988 | 64 | 84,266 |
07-17-2016 11:53 AM Last Post: McGlinchey |
Another danish restoration | Duze | 61 | 71,446 |
03-20-2016 08:58 AM Last Post: Duze |
'84 ae86 restoration project | HybriD07 | 19 | 24,887 |
10-13-2014 09:20 PM Last Post: HybriD07 |
TOYOTA COROLLA Ke70 - Restoration project | cke70 | 34 | 50,594 |
07-02-2014 10:12 PM Last Post: cke70 |
Black Limited restoration | slpery86 | 6 | 9,856 |
12-17-2013 09:22 PM Last Post: banpei |
