01-13-2005, 09:15 PM
Post: #61
The weight difference between 40 and 42 mm cranks is ~0.7 kg.
The most important advantages of later 4AGE's (esp. non-tvis) are higher CR and velocity (due to smaller intake ports). I personaly think that NA will be better with bluetop bottom&non-tvis head, turbo will take benefits of bluetop head and non-tvis bottom end (very similar to 4AGZE one!). PS: non-tvis internals include 7-ribs, oil squirters, massive rods, 42/20mm crank/pin, can work with 4AGZE pistons. |
01-15-2005, 09:26 PM
Post: #62
Just a very quick update: My engine is finally running. No problems whatsoever I'm getting the car back on Monday or Tuesday at the latest!
Pics on Monday! |
01-16-2005, 12:28 AM
Post: #63
Congratulations dorito. Glad to hear.
01-16-2005, 11:47 AM
Post: #64
Dorito way to go mate!
01-16-2005, 03:58 PM
Post: #65
Yay!
How long did it take you? Atleast 2 months I'd say. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
01-16-2005, 11:57 PM
Post: #66
Bravo dorito kai kales, grigores kai asfaleis boltes!
I will start repairing mine on Wednesday. Hope we'll meet someday... ΓΙΩΡΓΟΣ AE86 FANATIC!!! |
01-17-2005, 11:17 AM
Post: #67
Thank you guys! It has been a [u:4ddc69bb09]very[/u:4ddc69bb09] stressed out weekend. I can't wait to sit behind the wheel and start breaking it in.
Now on to the details. The T3 short-shift is in place. Installation is piece-of-cake and it feels a bit strange. The throw is indeed very much reduced, but it will take some practice to get used to. The exhaust manifold has been drilled and fitted with a lambda sensor (needed by AE92 ECU). The engine gave us a bit of trouble, but it was fixed fianally. The starter was turning, but it just wouldn't start. First we checked the spark plug wires. They were live. Then we checked the fuel. The injectors were spraying allright. Then we checked compression. Compression was good. Then we noticed that in-cam and ex-cam lobes were pointing at the same direction for a given cylinder. Duuuuh! Apparently the mechanic had started rebuilding this particular motor sometime in the past, had gone as far as removing the cams and then aborted the project and put it back together hastily. As a result, when he marked the cam gears to disassemble it for me, the cam position was all f**ked up and he didn't notice when putting it back together. So basically in and ex valves were opening upp at the same time, loosing compression and letting the mixture go straight out the exhaust. But we fixed that too and it started 1st time. So now, all is in place, except some panels in the car and minor things to be strapped down in the engine bay. I should be getting it back today or tomorrow. Will post first pics on the road when I have them. |
01-17-2005, 11:38 AM
Post: #68
Damn man.Stupid mechanics.
Can i come with you tommorow to take the hachi? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
01-17-2005, 11:41 AM
Post: #69
Shure dude! I'll let you know.
01-17-2005, 03:51 PM
Post: #70
Thnx stupi-rito86.
That's your new nick name now. No certain reason for it, just that you write "shure" instead of "sure". But then I think I make even more mistakes myself. CAll me tommorow ok? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
Full restoration... | Blade1988 | 64 | 83,715 |
07-17-2016 11:53 AM Last Post: McGlinchey |
Another danish restoration | Duze | 61 | 71,047 |
03-20-2016 08:58 AM Last Post: Duze |
'84 ae86 restoration project | HybriD07 | 19 | 24,593 |
10-13-2014 09:20 PM Last Post: HybriD07 |
TOYOTA COROLLA Ke70 - Restoration project | cke70 | 34 | 50,244 |
07-02-2014 10:12 PM Last Post: cke70 |
Black Limited restoration | slpery86 | 6 | 9,801 |
12-17-2013 09:22 PM Last Post: banpei |
