Group a homologation questions
05-11-2015, 09:31 PM (This post was last modified: 05-11-2015 09:32 PM by ditn.)
So im checking the Group a homologation papers for the ae86 2 door and im wondering,
there is almost nothing in there that can be done to do the engine.
Am im missing something or??
that cant be right for an ae86 grp a car rallycar
05-12-2015, 01:52 AM
I have the full set of homologation papers, I'll have a look at mine. Maybe there are some differences.
Can you tell me the homologation number that you have ?
05-12-2015, 09:38 PM
A-5179 and n-5179 for grp a and grp n 2 door is mine.
i think its same.
05-13-2015, 06:04 PM (This post was last modified: 05-13-2015 11:59 PM by oldeskewltoy.)
from the A-5180 papers.... 3 door/hatchback
1599cc max
minimum rod mass - 431 grams - length 122mm - big end diameter 43mm (so no 42mm cranks!)
minimum crank mass - 11540 grams
flywheel cast iron minimum mass - 7060 grams
55mm T/B
injectors in head (not in intake)
maximum valve lift - 7.2mm - clearances .2mm, and .25mm
number of intake manifold elements - 2 (TVIS plate and intake??)
exhaust cast iron
max intake valve diameter 30.7mm, 6mm stem
max exhaust diameter 25.7mm, 6mm stem
wet sump oil system
As I read it... that leaves a LOT of room for special machining, and head porting. It also has cam lift listed... but not durations.... no mention of compression ratios either.... no mention of adjustable cam pulleys either....
Dan -
05-16-2015, 02:46 PM
Some more engine info. here:
http://forums.toymods.org.au/index.php?t...3&start=0&
05-17-2015, 05:22 PM
thanks for info Smile
its really weird some say if its not in papers it has to be oem and other say if its not in papers its free.
06-01-2015, 09:15 PM
someone from organisation came and he said everything thats not in the papers has to standard.
Kinda sucks,im going group n then
06-01-2015, 09:37 PM
But isn't group n even more stict?
Daily Beater: Civic EG5
Work in progress Car: AE86
06-01-2015, 10:48 PM (This post was last modified: 06-01-2015 10:57 PM by ditn.)
Yes its is,
But the truth is in group a with basicly a stock engine there is no way you can compete.
However in group n its a very competitive car
06-02-2015, 11:05 AM
Go group E1 Smile
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 3,881 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 1,988 04-30-2024 09:46 PM
Last Post: Mylesmck
  Brake Bias Questions mad.matt 10 12,616 01-03-2019 04:54 AM
  wider rear axle,track width,suspension questions ditn 6 9,818 10-18-2016 11:50 AM
Last Post: fantapants
  Suspension questions leon205gti 17 16,169 04-30-2016 09:26 PM
Last Post: krullibull
