HELP!!!!! Fuel pump has no power!!!!!
03-08-2008, 02:43 PM
Well i just put a fresh 4agte in and everything is working fine but it isnt pumping fuel, everything else in the circuit has power but the fuel pump isnt getting any of it. The only thing i cant locate is the circuit opening relay, does anyone know where this is or if any connector under the hood i may have left unhooked is the cause? Has anyone encountered this problem before? PLEASE HELP!!!
Slide to side worldwide!!
[Image: AEU86 AE86 - HELP!!!!! Fuel pump has no power!!!!!]
03-08-2008, 03:07 PM
ps i removed the afm, could that not being connected have any affect?????
03-08-2008, 04:15 PM
The circuit opening relay should be somewhere above the ECU on the passenger side footwell.
03-08-2008, 04:29 PM
is it the black box? and what about the afm would that make a difference?
03-08-2008, 05:20 PM
make own cables from + to pump and to a earth point, and a switch + fuse. then u dont have to think about the relay Big Grin or else find the relay.
DonĀ“t Think About The Past,
Live In The Present And
Dream About Tomorrow
03-08-2008, 08:20 PM
lol!!! i was thinking of doing that but i figured if i can find the relay than i wouldnt have to worry about that
03-08-2008, 08:26 PM
does the AFM matter if it is disconected or not? could that stop the fuel pump from working seeing as they are connected to the same circuit
03-13-2008, 02:43 PM
got it working
  20v BT - which oil pump? Mylesmck 4 2,867 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 5,341 04-29-2022 05:45 AM
  Exhaust has white smoke coming out and I dont know why... mister86 3 4,694 01-19-2020 12:06 AM
Last Post: Power_uP
  fuel line hose from the pump Wikizz 4 6,109 10-16-2017 07:11 PM
Last Post: jdm86gtz
  Has anyone tried BC Racing coilovers? AlexKTM 9 12,121 09-05-2016 12:28 PM
