HELP!!!!! Fuel pump has no power!!!!!
03-08-2008, 02:43 PM
Well i just put a fresh 4agte in and everything is working fine but it isnt pumping fuel, everything else in the circuit has power but the fuel pump isnt getting any of it. The only thing i cant locate is the circuit opening relay, does anyone know where this is or if any connector under the hood i may have left unhooked is the cause? Has anyone encountered this problem before? PLEASE HELP!!!
Slide to side worldwide!! ![]() |
03-08-2008, 03:07 PM
ps i removed the afm, could that not being connected have any affect?????
03-08-2008, 04:15 PM
The circuit opening relay should be somewhere above the ECU on the passenger side footwell.
03-08-2008, 04:29 PM
is it the black box? and what about the afm would that make a difference?
03-08-2008, 05:20 PM
make own cables from + to pump and to a earth point, and a switch + fuse. then u dont have to think about the relay
![]() DonĀ“t Think About The Past, Live In The Present And Dream About Tomorrow |
03-08-2008, 08:20 PM
lol!!! i was thinking of doing that but i figured if i can find the relay than i wouldnt have to worry about that
03-08-2008, 08:26 PM
does the AFM matter if it is disconected or not? could that stop the fuel pump from working seeing as they are connected to the same circuit
03-13-2008, 02:43 PM
got it working
20v BT - which oil pump? | Mylesmck | 4 | 2,882 |
Fuel pump issue | DJexor | 11 | 5,361 |
Exhaust has white smoke coming out and I dont know why... | mister86 | 3 | 4,701 |
01-19-2020 12:06 AM Last Post: Power_uP |
fuel line hose from the pump | Wikizz | 4 | 6,132 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 12,160 |
09-05-2016 12:28 PM Last Post: mad.matt |
