Half shaft problem
11-04-2006, 08:39 PM
Half shaft problem
Does anyone know what shafts the ones in these pictures are? My car came with a drum axle and I have broken a half shaft recently. One of the shafts is a normal small type shaft but my drum shaft is longer and has different bearings. Can anyone tell me what other model Toyota's use this and if I can buy one somewhere? I need one ASAP. The spline is the zenki (small shaft) type.
Thanks James ![]() ![]() |
11-05-2006, 12:08 PM
Half shaft problem
The axle on the right looks like a regular ae86 axle.. the one on the left looks like it belongs on an old celica or maybe an sr5 axle..
11-06-2006, 11:36 AM
Half shaft problem
Left-SR5 (drum), right - GTS (disc) - my suggestion.
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 7,277 |
Steering shaft issue | Ryo | 15 | 13,454 |
11-19-2018 09:52 AM Last Post: Ivan141 |
Half Shafts Poblem | AlexKTM | 6 | 7,099 |
04-23-2018 04:42 PM Last Post: MIGGZFSU |
Propeller shaft universal joint | kawo | 1 | 4,540 |
05-19-2014 11:05 AM Last Post: Uzelac |
Play in prop shaft (diff end) | phill 92 | 14 | 15,301 |
08-07-2012 02:13 PM Last Post: phill 92 |
