Half shaft problem
11-04-2006, 08:39 PM
Half shaft problem
Does anyone know what shafts the ones in these pictures are? My car came with a drum axle and I have broken a half shaft recently. One of the shafts is a normal small type shaft but my drum shaft is longer and has different bearings. Can anyone tell me what other model Toyota's use this and if I can buy one somewhere? I need one ASAP. The spline is the zenki (small shaft) type.
Thanks
James
[Image: AEU86 AE86 - Half shaft problem]
11-05-2006, 12:08 PM
Half shaft problem
The axle on the right looks like a regular ae86 axle.. the one on the left looks like it belongs on an old celica or maybe an sr5 axle..
11-06-2006, 11:36 AM
Half shaft problem
Left-SR5 (drum), right - GTS (disc) - my suggestion.
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 6,666 07-31-2019 11:28 AM
  Steering shaft issue Ryo 15 12,554 11-19-2018 09:52 AM
  Half Shafts Poblem AlexKTM 6 6,618 04-23-2018 04:42 PM
Last Post: MIGGZFSU
  Propeller shaft universal joint kawo 1 4,226 05-19-2014 11:05 AM
Last Post: Uzelac
  Play in prop shaft (diff end) phill 92 14 14,311 08-07-2012 02:13 PM
Last Post: phill 92
