Handbrake woes
04-12-2007, 09:00 AM
Handbrake woes
Kudos on the writeup!
04-13-2007, 06:38 AM
Handbrake woes
That write up works great, I missed the edit as well so one side was bad ass the other was lazy but fixed the issue after redoing it!
04-13-2007, 10:12 PM
Handbrake woes
Thanks to everyone I have a car that is now legal
My advice if you have a problem with the handbrake is to follow the write up, I used synthetic grease as advised by the way. An analogue brain in a digital World |
04-12-2008, 10:08 PM
Handbrake woes
Ok, old thread, I know, but this handbrake adjustment thingy is important! (and please refrain from replying that "we don't need a handbrake to go sideways, just kick the clutch, or install a SR20DET")
I did this adjustment but I think I screwed up, no improvement. Might of course be my handbrake-cables that have rusted, or stretched too much, but pulling the handbrake makes the handbrake-levers on the calipers move, so I think cables and levers are ok. Maybe a piston overhaul is due, cause it was a bitch to turn (though I probably should have at least taken the cap of the brakefluid reservoir, or opened the bleeding nipple on the caliper a bit). I probably need to know more about how the rear caliper pistons work, because I don't get how (after turning the piston "in" / clockwise, and out again) applying pressure on the piston + pumping the brakepedal will make the piston adjust itself outwards (closer to the inside pad). I thought it adjusts itself further out when it senses less pressure (when pads or discs wear thinner). And by the way, does the handbrake-lever on the caliper push the piston hydraulicly or mechanically? I assume the screw inside the piston, which makes itself longer after pad/discwear is the "adjuster", and it's this that makes both footbrake and handbrake work when discs/pads get thinner? As a supernoob I tend to ramble on, sorry 1987 Levin 3d - daily drifter (to be) 1990 SW20 MR2 w/ gen3 3S-GTE - daily poser |
04-12-2008, 10:39 PM
Handbrake woes
:wink: |
04-12-2008, 11:05 PM
Handbrake woes
...I guess I had that coming... Congratulations Eric, you're the first to take the bait....
But I guess you don't need a handbrake if you live in Holland og Denmark.... it's all flat... Not so up here By the way, anyone; With a hydraulic handbrake, can you use it while parking? (as someone said it wasn't practical in a daily driver....) 1987 Levin 3d - daily drifter (to be) 1990 SW20 MR2 w/ gen3 3S-GTE - daily poser |
04-13-2008, 08:54 AM
Handbrake woes
hydrolic handbrake doesnot work as a parking brake because you cannot lock it up, you can just pull the handle and it will lock as long as you pull the handle.
and yes we need handbrakes in Holland but only in Limburg |
04-13-2008, 09:06 AM
Handbrake woes
if you could make it lock up, it could work just as good
04-14-2008, 12:36 PM
Handbrake woes
Competition pads won't help either. They need to be hot to work properly.
Hydraulic handbrake will improve things, but isn't legal in all countries, I believe. Leaving the cable in place as well, should get round this. Just make sure it's adjusted so that the hydraulics work before the cable. http://www.AE86imports.0catch.com |
04-14-2008, 12:38 PM
Handbrake woes
Or just replace your rear caliper. It's probably the inner mechanism in the caliper that doesn't work anymore.
Handbrake adjustment discs? | DMC | 8 | 1,671 |
Hydraulic handbrake with stock rear brakes | Dino86 | 11 | 15,257 |
07-11-2014 08:33 PM Last Post: Dino86 |
Brake woes | totta Crolla | 10 | 10,150 |
10-31-2011 10:46 AM Last Post: YoShImUrA |
How to make the handbrake more effective? | heshan | 8 | 11,108 |
04-27-2011 03:43 PM Last Post: heshan |
Handbrake issues | heshan | 4 | 5,256 |
12-13-2010 07:15 AM Last Post: assassin10000 |
