How to make the handbrake more effective?
04-20-2011, 09:30 PM
Guys, no matter how much I tighten the cable from the adjuster near the lever, my rear wheels won't lock up?
I assume its due to the following reasons:
1. Rear Disc worn out
2. Cable not taut enough
3. Pistons are not working hard enough in the calipers
4. Bad brake pads
Guys any suggestions on how to improve this? I really would like to get the rear sideways using the handbrake and not just with power.. With a small and crowded roads in Sri Lanka its really dangerous.. Sad
Please help.
thanks,
heshan.
Cheated on my いたずらな女の子 and now I can't get enough of her..
04-20-2011, 10:05 PM
Well, you pretty much answered the question yourself...
What you need to do, get new discs + pads and check if the caliper works properly. (self adjusting mechanism)
While doing that bleed your brake system, too.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
04-21-2011, 09:57 AM
Usually the adjuster mechanism is fooked.
Drifting on crowded and narrow public roads is fucking stupid.
http://www.aeu86.org/viewtopic/diy-how-t...adjustment
This wouldnt look out of place on the howto pages on the aeu86 mainpage either methinks... so Banpei if you're reading this..
04-21-2011, 06:49 PM
heshan Wrote:1. Rear Disc worn out
No, no such thing as worn out until it breaks or the pads aren't conforming with the disks concentric grooves.
Maybe. Adjusted right & all pivot points & linkage & cables lubed?
Maybe. pistons could be frozen/corroded in caliper.
4. Bad brake pads
No. Good pads for an easy handbrake would be too soft & lockup easily when using the hydraulics & overheat quickly.
Good luck.[/b][/b]
04-22-2011, 11:16 AM
I had the same issue but then I found out that Im using the handbrake the wrong way. Its all about transfering the weight around.
Small and twisty roads are fun but dont even think about doing this in traffic...
86ers.org
AE86 x GXE10
04-22-2011, 04:11 PM
Thats the problem of this handbrake setup, allen said most of it.
But why cannot just use 1,R gear while parking? I gave up and do that automatically everytime.
http://www.86ers.org
04-27-2011, 03:43 PM
Thanks guys for your feedback on this.
Is there any write up on what the changes are to install a hydraulic handbrake?
  Handbrake adjustment discs? DMC 8 2,707 03-10-2024 08:08 PM
Last Post: DMC
  Hydraulic handbrake with stock rear brakes Dino86 11 16,892 07-11-2014 08:33 PM
Last Post: Dino86
  the many more 4AGZE questions topic ditn 39 44,877 05-31-2013 11:35 PM
Last Post: ditn
  More positive gear change phill 92 12 13,139 05-21-2012 10:51 PM
Last Post: phill 92
  Velocity stacks = more power, now which to get? 4000GT 38 54,248 02-22-2012 01:19 AM
Last Post: jondee86
