How to make the handbrake more effective?
04-20-2011, 09:30 PM
Guys, no matter how much I tighten the cable from the adjuster near the lever, my rear wheels won't lock up?
I assume its due to the following reasons: 1. Rear Disc worn out 2. Cable not taut enough 3. Pistons are not working hard enough in the calipers 4. Bad brake pads Guys any suggestions on how to improve this? I really would like to get the rear sideways using the handbrake and not just with power.. With a small and crowded roads in Sri Lanka its really dangerous.. Please help. thanks, heshan. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
04-20-2011, 10:05 PM
Well, you pretty much answered the question yourself...
What you need to do, get new discs + pads and check if the caliper works properly. (self adjusting mechanism) While doing that bleed your brake system, too. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-21-2011, 09:57 AM
Usually the adjuster mechanism is fooked.
Drifting on crowded and narrow public roads is fucking stupid. A wheel to steer the front of the car A pedal to steer the rear |
http://www.aeu86.org/viewtopic/diy-how-t...adjustment
This wouldnt look out of place on the howto pages on the aeu86 mainpage either methinks... so Banpei if you're reading this.. FABRICA MI DIEM, PVNC! |
04-21-2011, 06:49 PM
heshan Wrote:1. Rear Disc worn out Good luck.[/b][/b] |
04-22-2011, 11:16 AM
I had the same issue but then I found out that Im using the handbrake the wrong way. Its all about transfering the weight around.
Small and twisty roads are fun but dont even think about doing this in traffic... 86ers.org AE86 x GXE10 |
04-22-2011, 04:11 PM
Thats the problem of this handbrake setup, allen said most of it.
But why cannot just use 1,R gear while parking? I gave up and do that automatically everytime. http://www.86ers.org All the hachies that Daytona can only dream about. |
04-27-2011, 03:43 PM
Thanks guys for your feedback on this.
Is there any write up on what the changes are to install a hydraulic handbrake? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
Handbrake adjustment discs? | DMC | 8 | 1,699 |
03-10-2024 08:08 PM Last Post: DMC |
Hydraulic handbrake with stock rear brakes | Dino86 | 11 | 15,314 |
07-11-2014 08:33 PM Last Post: Dino86 |
the many more 4AGZE questions topic | ditn | 39 | 40,512 |
05-31-2013 11:35 PM Last Post: ditn |
More positive gear change | phill 92 | 12 | 11,789 |
05-21-2012 10:51 PM Last Post: phill 92 |
Velocity stacks = more power, now which to get? | 4000GT | 38 | 49,949 |
02-22-2012 01:19 AM Last Post: jondee86 |
