Head Gasket Replacement - Block Surface Question ??
05-17-2009, 08:23 PM
I am in the process of replacing my head gasket. I had the head cleaned up at the machine shop. There is no warping and the surface if perfect. - I bought a new head gasket and head bolts as well.
I cleaned up the block and got all the gasket material off. - Around number 4 and 1 cylinders, there is a little bit of roughness and some minor scratches here and there through the surface.
Bearings were replaced about 6 years ago and compression is great. - I don't really want to rebuild the block right now, but was concerned that the block surface may need some machining.
Like I said, the head is good to go, but I am wondering how lenient I can be with the block. - I did check it with a precision straight edge and feeler gauge, and there is not warping.
<a href="http://www.imagebam.com/image/a91d8c35896914/" target="_blank"><img src="http://thumbnails13.imagebam.com/3590/a91d8c35896914.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/a0793b35896915/" target="_blank"><img src="http://thumbnails18.imagebam.com/3590/a0793b35896915.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/fcf3bb35896917/" target="_blank"><img src="http://thumbnails16.imagebam.com/3590/fcf3bb35896917.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/a2524235896919/" target="_blank"><img src="http://thumbnails15.imagebam.com/3590/a2524235896919.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/f265b435896920/" target="_blank"><img src="http://thumbnails12.imagebam.com/3590/f265b435896920.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/475f8c35896921/" target="_blank"><img src="http://thumbnails18.imagebam.com/3590/475f8c35896921.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/fef6b635896923/" target="_blank"><img src="http://thumbnails18.imagebam.com/3590/fef6b635896923.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/05e91635896924/" target="_blank"><img src="http://thumbnails14.imagebam.com/3590/05e91635896924.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/74eda635896926/" target="_blank"><img src="http://thumbnails14.imagebam.com/3590/74eda635896926.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/85203535896927/" target="_blank"><img src="http://thumbnails2.imagebam.com/3590/85203535896927.gif" alt="imagebam.com"></a>
<a href="http://www.imagebam.com/image/11612935896929/" target="_blank"><img src="http://thumbnails17.imagebam.com/3590/11612935896929.gif" alt="imagebam.com"></a>
06-10-2009, 10:17 AM
which would be the best gasket in a case like this?
06-11-2009, 10:24 AM
Can't beat OEM for sealing
Dan -
06-11-2009, 02:24 PM
oldeskewltoy Wrote:Can't beat OEM for sealing
+1
agree!
  Exhaust replacement banpei 35 5,356 10-24-2024 10:45 AM
Last Post: decryphe
  Question about 4AG 20v Engine Block CHACAMAN 1 1,750 06-10-2022 05:17 PM
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 5,758 11-05-2021 08:17 PM
Last Post: gh0st
  4AGE block differences explained (incl. some eyecandy) Bean 46 89,275 05-05-2019 04:03 AM
Last Post: Rocker100
  BT head with ST block. CHOPKIN2 6 7,391 02-06-2018 06:27 PM
