Head from AFM to MAP?
05-19-2008, 10:53 AM
Does head from engine with AFM can be put on engine with MAP, does the termoswithes are the same bolt on, or must be some modification. If must be some modification, please tell what to do. Thanks...
http://www.driftclub.rs |
05-19-2008, 06:21 PM
The cylinder heads on TVIS engines are all the same (AE86, AW11, AE82). The sensors MAY be different.
Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
AFM to Map Conversion | ps13michi | 3 | 2,917 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,512 |
extracted freedom ecu 16v ignition map | ditn | 7 | 8,609 |
Bluetop AFM with air filter | izanagi | 4 | 6,808 |
04-29-2016 07:29 PM Last Post: oldeskewltoy |
smallport question AFM or MAP? | fax0815 | 5 | 8,066 |
05-17-2014 05:07 AM Last Post: jondee86 |
