Head light help
01-05-2008, 03:20 AM
Head light help
i got a late type levin.
after i fit the HID light the side light not working. but when put the single on, its work. the things is will the HID system jam-ed the side light. thank you |
01-05-2008, 02:40 PM
Head light help
if the hid has 2 or more ground cables connect them all to the chassis an if it is possible 1 or more on the battery
if it is not solved then reconnect the whole hid wires from start and try to get a good clean groundwiring point always keep in mind the better the ground connection point the better everything works Love it or hate. It still is and still stays a beautifal car!!! Oooohw how I love the Ae86 You have the right to remain stupid !!! Toyota for life !!! |
01-06-2008, 01:13 AM
Head light help
thanks for the information. but the problem is the side light not the HID.
01-06-2008, 02:22 PM
Head light help
FYI: the side lights are powered directly from the "TAIL" fuse. This fuse only gets 12v switched to it when you turn the lights on. So in theory, if you wired the HID's correctly, you should not be having any problems. Best re-check everything. Also have a look if your license plate lights and other stuff in the rear still work when the sidelights are not working.
Need help with the Headlights, One light doesn’t retract | Sgonzalez | 4 | 11,099 |
12-29-2007 10:16 PM Last Post: Sgonzalez |
need help combining 4AC block with 4AG head | Max_toy | 28 | 30,387 |
07-15-2007 10:49 AM Last Post: Max_toy |
AE86 tail light Lens number help | Rick | 8 | 11,960 |
02-13-2007 06:39 PM Last Post: Chixican |
