Headlights - only high beam working
01-10-2015, 11:59 AM
RE: Headlights - only high beam working
The AE86 has a constant 12V supply to both the high and low beam
filaments in the OEM setup. The filaments are turned ON by connecting the filament to ground. The high beam indicator light is connected to the low beam circuit on the ground side of the filament, and held OFF while the low beam filament is grounded. When the ground is removed from the low beam and applied to the high beam (as the dip switch is moved) the indicator now receives 12V and is illuminated. Kind of counter intuitive, but that is the Toyota way The behaviour that you have described indicates that there is a break in the low beam switching circuit. There is no ground being supplied for the low beam filaments when the switch is in the dip position. Check to see if you have 12V on the Red-Green wire that connects to pin B6 on the headlight switch when the switch is in the high beam position. The other end of this wire should be on pin A11 in JB3. If you have 12V at B6, moving the switch to the low beam position should provide a ground for B6, turning the low beam filaments ON and the high beam indicator light OFF. If it does not, then the problem is inside the switch. Cheers... jondee86 |
Messages In This Thread |
Headlights - only high beam working - Jezza_hr - 12-28-2014, 08:31 PM
RE: Headlights - only high beam working - Uzelac - 12-28-2014, 11:26 PM
RE: Headlights - only high beam working - Jezza_hr - 12-28-2014, 11:52 PM
RE: Headlights - only high beam working - jondee86 - 01-10-2015 11:59 AM
Brake lights not working | takumi_mt | 2 | 639 |
03-07-2024 03:42 PM Last Post: takumi_mt |
High-beam warning lamp | Mylesmck | 4 | 1,410 |
07-21-2023 07:44 AM Last Post: banpei |
Engine stress at high speeds | gh0st | 6 | 2,392 |
08-30-2022 07:11 PM Last Post: Power_uP |
Help me AEU86, you're my only hope | Nakilad | 38 | 15,474 |
04-10-2021 05:19 PM Last Post: Nakilad |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 20,859 |
