Help needed with 4AGZE supercharger
09-28-2012, 11:40 AM
Guys,
Could anyone tell me what possible reason could the supercharger clutch would slip after engaging? When I'm flooring there was a belt slipping noise which I thought was my A/C belt but my mechanic says after some investigations its my supercharger clutch slipping.
Any pointers? Could it be there the magnatism isn't sufficient? Could it be due to any drop in electricity coming into the SC? Any other reasons?
Would really appreciate any help.
Thanks.
Cheated on my いたずらな女の子 and now I can't get enough of her..
09-28-2012, 07:32 PM
anyone?
10-30-2012, 06:13 AM
The clutch faces will wear with use, on second hand units I have used I had the clutch faces machined but you need to make sure the air gap is set within specs, I have a manual I can send you if you like.
[Image: AEU86 AE86 - Help needed with 4AGZE supercharger]
Corolla Levin SR 1984 AE-85 (Project car)
Corolla Runx Z 2002 (Runabout)
10-30-2012, 03:07 PM
@ Rick Yes please.. Would really appreciate it if you could send me the specs.
Thanks.
10-31-2012, 08:44 AM
If you like to send me a PM with your email address I can send it through to you.
  Help needed totta Crolla 3 4,528 05-15-2020 10:07 AM
Last Post: totta Crolla
  Some wiring help needed DJexor 5 6,254 05-18-2019 01:50 PM
Last Post: DJexor
  Help needed: is it 1 way or 1.5way LSD Dino86 2 4,166 05-17-2019 09:08 AM
  Help Needed with steering. phill 92 1 7,084 10-18-2013 02:58 PM
Last Post: fax0815
  Help needed with door mirror glasses T_AE86 3 5,584 06-29-2013 01:16 AM
Last Post: T_AE86
