Help on Tyre selection - asap - PLEASE!
01-24-2011, 09:20 PM
Hello,
I have original 14 inch rims with tire size : 195/60/R14
I want to get my 13 inchs rims fitted...
13 x 7.0J ET-7
Wat tires/tire size should I use to keep it close to the OEM distance...
165? to pull the tires and make the rims pop out a bit more?
165/60/13? I have noooo clue whatsoever about tires and all that... Sorry.
Please help! Thanks!!!
This is the problem now Tongue
[Image: AEU86 AE86 - Help on Tyre selection - asap - PLEASE!]
-DWG- Drift Wolf Gaming
01-24-2011, 09:31 PM
165/75R13 would match OEM size, but it's probably easier to check what sizes are available at all in 13" and then plug the numbers in here http://www.carbibles.com/tyre_bible_pg4.html does all the math for you Wink
01-24-2011, 09:42 PM
Thanks!
I just came across this link also http://www.buggyboys.be/nl/tech_tellerafwijking.htm
And found out if I would choose this tire-size : 175/70/13
The height would then be 1 cm smaller and -5cm with the wheel running
So it would almost be the same with OEM but the wheels would spin faster vs the OEM size.
01-24-2011, 10:26 PM
185/60/13
Probably the best selection of tyres in this size.
Plenty of used race tyre bargains available for drifting in 13" too :wink:
Don't lower the front of the car too much in relation to the back.
01-24-2011, 10:38 PM
totta Crolla Wrote:185/60/13
Thanks... the lowering in front was due to the OEM size wheels... I did not know it was going to be THIS AWFULL with the new rims and tyres hahaha
I apologize for the nose-diving-look Big Grin
01-24-2011, 11:16 PM
That's the default size for the pizzacutter rims. Big Grin
01-30-2011, 11:18 AM
totta Crolla Wrote:185/60/13 Probably the best selection of tyres in this size.
Agreed. I used 185/60-13 slightly stretched onto that exact same wheel.
Cheers... jondee86
01-30-2011, 01:52 PM
Thanks again everybody... Yesterday I allready picked up the rims+tires
01-30-2011, 07:15 PM
Nice looking '86 there Jondee Smile
Can you please tell me the rim width and the offset of those wheels...
01-30-2011, 09:34 PM
Looking good! Thumbs up!
  TUV RHD AE86 Germany (help please) 4dori 9 6,759 07-17-2019 07:42 PM
Last Post: Hachigo83
  Carb question please help MIGGZFSU 3 4,586 03-29-2017 03:06 PM
Last Post: MIGGZFSU
  Whining noise HELP PLEASE izanagi 10 11,971 03-26-2015 06:48 PM
Last Post: Komba
  the connector saga (please help everyone) Bean 8 9,087 06-23-2014 01:13 PM
  Need help asap with 4ac to 4age!!!!!!! JDMjonSR5 6 12,520 05-14-2013 12:12 PM
Last Post: JDMjonSR5
