Help with Wiring
04-02-2007, 03:48 AM
Help with Wiring
Hey,
Can any one help out with a wiring diagram of a AE86?
Am putting mine onto Webbers but need to know what happens if I make the computer redundent. Does the computer run the dash?
I want to retain the ability of putting the car back on injection if for some reason I decide to, so don't want to cut original loom.
What are my options? Confused
Help would be wicked good!!!!!
Cheers
04-02-2007, 09:31 AM
Help with Wiring
We've already talked about using the original ECU for ignition when running carbs - check this thread;
http://www.aeu86.org/viewtopic/carbureti...4ag/t/4426
The only thing in the dash run by ECU is the 'check engine' -light, but it also controls the fuel pump so when using a mechanical distributor, you can't remove the ECU altogether unless you hardwire the pump to run.
04-02-2007, 10:41 PM
Help with Wiring
Sorry guys, didn't find it.
Big Grin
Cheers,
  Tail light wiring... Mylesmck 4 1,308 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 4,906 05-23-2022 10:00 PM
Last Post: The Doctor
  4A-GE wiring engine to chassis connectors Lykowsky 4 7,315 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 5,740 05-18-2019 01:50 PM
Last Post: DJexor
  AE86 Headlight + wiper wiring (levin) bozu 11 16,743 09-19-2017 02:06 PM
