High Compression Ratio ----> Detonation
03-26-2009, 12:57 AM
Post: #31
jondee86 Wrote:Yes... interesting thread Smile
BCPR6EY11... fairly certain these are the OEM "shopping basket" plugs.
I would be running at least one heat range colder.
Cheers... jondee86
My 4AGE is 131bhp at the wheels and I find these plugs work well in that I also have some NGK Iridium 8s but they are too cold.
03-26-2009, 06:24 AM
Post: #32
The heat range used should be chosen to suit the type of driving
you do. For everyday round town running the stock plug is most suitable
to avoid plug fouling. But for prolonged high speed/high load operation,
a colder plug will be better.
I would put in one heat range colder plugs when racing my car (stock
engine). For modified engines with increased power output, a colder plug
may be required for "spirited driving". But there will be an increased
risk of fouling if the same car gets caught up in city traffic.
Cheers... jondee86
  High-beam warning lamp Mylesmck 4 1,574 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 2,659 08-30-2022 07:11 PM
Last Post: Power_uP
  82mm Stock compression Pistons apardal 4 2,912 11-24-2021 04:26 PM
Last Post: apardal
  4AGE 16V engine overheat when at high speed chenfon 32 22,187 12-31-2020 06:39 AM
Last Post: chenfon
  working out compression ratios kazi 2 3,669 07-16-2019 08:22 PM
Last Post: oldeskewltoy
