High Compression Ratio ----> Detonation
03-26-2009, 12:57 AM
Post: #31
jondee86 Wrote:Yes... interesting thread My 4AGE is 131bhp at the wheels and I find these plugs work well in that I also have some NGK Iridium 8s but they are too cold. |
03-26-2009, 06:24 AM
Post: #32
The heat range used should be chosen to suit the type of driving
you do. For everyday round town running the stock plug is most suitable to avoid plug fouling. But for prolonged high speed/high load operation, a colder plug will be better. I would put in one heat range colder plugs when racing my car (stock engine). For modified engines with increased power output, a colder plug may be required for "spirited driving". But there will be an increased risk of fouling if the same car gets caught up in city traffic. Cheers... jondee86 |
High-beam warning lamp | Mylesmck | 4 | 1,779 |
07-21-2023 07:44 AM Last Post: banpei |
Engine stress at high speeds | gh0st | 6 | 2,898 |
08-30-2022 07:11 PM Last Post: Power_uP |
82mm Stock compression Pistons | apardal | 4 | 3,113 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 23,644 |
working out compression ratios | kazi | 2 | 3,842 |
07-16-2019 08:22 PM Last Post: oldeskewltoy |
