High engine oil temps - oil cooler discussion
06-02-2008, 10:32 AM
My engine oil temp is very high when drifting, it can go up to ~140C and even though I use 10W-60 oil, it's not good for the bearings.
I have the stock oil cooler but I don't know if it is connected correctly on the sandwich plate. I'm curious if the stock oil cooler has inlet and outlet ports or both are basically the same. The sandwich plate has the inlet and outlet port but I don't know which one is which one. Does anyone have any experiences with using double stock oil cooler - I mean connected them to each other? Does this conversion make any difference in the oil temps? Aftermarket oil coolers with thermostat type sandwich plates are surely the best decision to cool down the oil but also the most expensive, that's why I'm asking this. 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
06-02-2008, 02:27 PM
Hey Sutter,
common problem I have even got it around the same temps with "normal" circuit driving. A standard oil cooler goes from the sump to the oil filter plate to the sumppan. I will either buy a new oil cooler or buidl a double setup. That should improve it alot. (be aware that you will need more oil in your engine) btw I am running 5w60 Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
06-02-2008, 02:29 PM
I'm using double OEM coolers, and it sure helps...but is there a right "pattern" how to install the oil hoses to the cooler plate?
AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
06-02-2008, 02:46 PM
If you use an adapter plate there is no diffrence. (it just get routed from and 2 the engine. The switchplate ends in an open chamber.
Only if you have an standard oil cooler it goes from the oil filter plate to the sumppan Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
06-02-2008, 02:49 PM
robokill Wrote:A standard oil cooler goes from the sump to the oil filter plate to the sumppan. Thanks, robokill! Can you clarify this above sentence? Maybe only my English which lacks here but I don't really understand which port on the engine block is the inlet and the outlet.
06-02-2008, 02:50 PM
robokill Wrote:Only if you have an standard oil cooler it goes from the oil filter plate to the sumppan I think I see the situation now, thanks. 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
06-02-2008, 02:56 PM
robokill Wrote:Hey Sutter, any photos of such a setup ???? AE86 FANATIC!!! |
06-02-2008, 03:05 PM
Hi guys
I also run a double original setup with a thermostat switching from one to both. 2 will increase cooling capacity quite a bit and without a thermostat it takes some time to warm up the oil. I do not have an oil temp anymore but when I had one the temps were always stable around 100-110°C Was never on track though with the temp readouts though. My personal opinion is though that an aftermarket oilcooler would be the better choice if you can spend the money. This is just from what I have heard though and not from my own experience. And a plus is that you can get a oilfilter relocation kit with it which makes filter changes much easier. If pics are needed of the double setup, let me know. Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
06-02-2008, 03:08 PM
In case you have pics about the double setup, please post them here! Thanks.
06-02-2008, 03:22 PM
Here you go, 5 min fresh :wink:
| High-beam warning lamp | Mylesmck | 4 | 3,118 |
07-21-2023 07:44 AM Last Post: banpei |
| Mocal oil cooler & sandwitch plate ordered | Gtsi-R | 48 | 65,471 |
| Engine stress at high speeds | gh0st | 6 | 4,521 |
08-30-2022 07:11 PM Last Post: Power_uP |
| Oil cooler | totta Crolla | 0 | 2,256 |
| 4AGE 16V engine overheat when at high speed | chenfon | 32 | 31,496 |
![AEU86 AE86 - High engine oil temps - oil...discussion [Image: AEU86 AE86 - High engine oil temps - oil...discussion]](http://i65.photobucket.com/albums/h205/driftomachine/IMG_3424.jpg)
![AEU86 AE86 - High engine oil temps - oil...discussion [Image: AEU86 AE86 - High engine oil temps - oil...discussion]](http://i65.photobucket.com/albums/h205/driftomachine/IMG_3425.jpg)
