Home made Hachi Roku / AE-71
01-03-2006, 10:54 PM
SuperHessu Wrote:The Tercel has a 4A engine based on the same block, so it should fit in real easy, the clucth is my only concern...Ah, I didn't know the tercel has a 4A block. According to bill sherwood the 4AC has the same clutch as the 4AG: http://www.billzilla.org/4agstock3.htm And then your tercel isn't the "old" fwd tercel, but the 4wd corolla which was sold as tercel 4wd. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
01-03-2006, 11:12 PM
I don't know as what It's been sold elsewhere, but in Finland It's a Tercel, It has a gearbox from which you can choose to drive FWD or 4WD, and a slow 1st gear for rough places, it's a perfect hunting-car... I'll take the old engine out tomorrow and check out how the clucth fits...
Totally rebuilding an AE86... http://www.fintoys.net http://www.findori.net http://www.koti.mbnet.fi/teemu-t |
01-03-2006, 11:15 PM
hmmmm .... i think you gave as an idea for making a 4WD Hachi ???
AE86 FANATIC!!! |
01-04-2006, 09:13 PM
I've seen 4WD Tercles in Denmark as well... Too bad about your hachi, but it is a lot of work :!:
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
01-04-2006, 09:17 PM
Well I took the 4A out of the Tercel tonight, and notest that the clucth fits fine, but the oilpan needs to be changed because the front driveshafts are right under the engine, and so the oilpan is really a really small one... Tomorrow I'll start planning of how get the new one in and running properly...
I woulnd't build a 4wd hachi, but if you will, I bet the Tercels front suspension would also be the easiest one to convert to a hachi... Totally rebuilding an AE86... http://www.fintoys.net http://www.findori.net http://www.koti.mbnet.fi/teemu-t |
01-05-2006, 12:44 AM
This the one?
01-05-2006, 11:11 AM
4WD transmission is weaker than AE86 one.
01-05-2006, 06:33 PM
Yes our Tercel is exactly that model, looks a little different in Finland thou... And yes the 4WD transmission is weaker, but it will hold up for a small test drive with the 4A-GE... Just found out that I'll have to use the Tercels engine mounts, so the GT's alternatormount won't fit, but I guess I'll just use Tercel's, will have to use it's pulleys too thou... A bit more extra work, but it doesn't help to stop and cry about it...
01-06-2006, 11:16 AM
Ain't this funny, I had the 4age in a bench in which I was building it, I changed all the reguired parts, engine mounts, oilpan, a few waterpipes etc... So I had all the other parts changed but the clutch plate and assembly because the bench was blocking them, so I lift the engine up with a whinch on the roof so I can install the clucth and assembly, pretty soon I found out that Tercel's assembly has 6 bolts and GT's 8!! GT's assembly is a lot bigger so it won't fit in Tercels gearbox, and I can't use the Tercels Counting in the time I used to dig the Tercel out of the snow and disassembling it's engine, I've done 2 days of work for nothing, and I still have to change all the parts back and start thinking how to get the engine running... :roll:
EDIT: Mixed up the words, I was talking about the flywheel ofcourse... Totally rebuilding an AE86... http://www.fintoys.net http://www.findori.net http://www.koti.mbnet.fi/teemu-t |
01-07-2006, 04:15 PM
Damn, that's tough luck. :roll:
Project "Roku-ju" TA60 Carina | Motax | 24 | 38,062 |
03-05-2014 10:21 AM Last Post: Motax |
New hand made extractors | montrueno | 3 | 5,435 |
09-07-2013 04:45 PM Last Post: tomtom |
Bastian's Hachi-Roku Project | BastianAE86 | 17 | 20,597 |
07-19-2007 11:50 AM Last Post: Hurna |
no more hachi roku.... | TE71corolla | 16 | 15,544 |
01-15-2007 11:33 PM Last Post: delange |
Ian Bergin's Ae86 - Made In Dublin '2! | Ian - AE86 | 12 | 13,384 |
12-04-2006 06:52 PM Last Post: Denmark |
