Hot oil filter - a problem?
01-01-2014, 04:19 PM
Hi
Using an aftermarket exhaust my oil filter gets very hot. Has anyone heard of reliability issues because of this? I am wondering how it affects my oil temperature. A relocation kit would be "easy" but also add another component that can fail.
01-01-2014, 06:03 PM
I had the same problem with my exhaust header. I was actually blistering the paint on the oil filter. I made a cylindrical shaped heat shield, and attached it to the filter with a hose clamp. I have about a 4mm air gap between the filter and the heat shield which was enough to resolve problem. Dave W
01-02-2014, 10:56 AM
common problem with aftermarket headers as they ditch the original heatshield. Make a new one like Dave or have the header heatwrapped.
In general if you got a good oil cooling system it will be fine while driving. I would address it though especially for the moment when you stop. the header will still be hot but no more oilflow this might heat the oil inside the filter to a level where it might start building up and get caked and in turn block flow.
01-02-2014, 04:39 PM
My header is already wrapped but fabricating some sort of shield is a good idea - thanks!
01-03-2014, 09:33 PM
have you think to use a spacer to the header? Smile
4age 16v to FR 20VT
Thumbs Up ITB filter options mister86 1 3,640 12-06-2020 10:44 AM
  Placement location fuel filter bozu 0 3,600 12-01-2016 11:06 AM
Last Post: bozu
  Bluetop AFM with air filter izanagi 4 7,334 04-29-2016 07:29 PM
  trans oil, lsd oil change Apolan 9 17,644 10-01-2014 03:57 PM
  Engine cranks slowly when hot... but starts Dino86 9 14,552 02-03-2014 08:04 PM
Last Post: Dino86
