How do you make your handbrake lockup?
01-02-2005, 10:03 PM
Hi All,this a a newbi from Denmark,
I would really like to know how you make the handbrake,so i can lock the wheel, It seem that it´s impossible on mine,even with brand new calipers. ![]() regards from denmark, Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
01-02-2005, 10:39 PM
Hi Skassa
![]() Did you change the hand brake cable? They seem to get more flexible whith time. The guys I know who uses their AE86 for rally have hydraulic hand brakes... As far as I recall it isnt too expensive and I know that you arent going to use it as a daily driver so thats not problem either ![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
01-02-2005, 11:12 PM
handbrake ??? i thought we use normal brake and gas pedal to turn the car?
01-03-2005, 12:14 AM
Maybe handy if you could lock your wheels when it is parked
01-03-2005, 12:15 AM
mabey you should put a litre of NOS under that "handbrake" instead? THAT would make your car loose controle!
Ofcourse you would be in the ditch with a popped headgasket and a gearknob through your heart, so I advise you on changing the handbrake cable ![]() |
01-03-2005, 12:28 PM
Before we all go advising you to change the cable (which is not a bad idea actually), first I would like to ask if you have tried adjusting it.
01-03-2005, 04:38 PM
and here comes Ivanhoe to save the day
![]() ![]() that's the sort of thinking i realy like. not buying new items the moment a problem arise, but first check if the old ones are realy done for. Speaking of locking your rear wheels: Mine could use some adjustment as well :wink: He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
01-03-2005, 04:44 PM
No one needs the handbrake just slam it in rewerse at the entrance fo the corner and you will be fine.
01-03-2005, 04:57 PM
s.bjelke Wrote:No one needs the handbrake just slam it in rewerse at the entrance fo the corner and you will be fine.Hahahahaha! ![]() ![]() |
01-03-2005, 04:58 PM
s.bjelke Wrote:No one needs the handbrake just slam it in rewerse at the entrance fo the corner and you will be fine.Reverse is a bit harsh: you won't be able to park you car anymore... You could easialy just put the car two gears down to get the same effect. :lol: 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Handbrake adjustment discs? | DMC | 8 | 1,984 |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,055 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,270 |
How would/have you rebuild your 4age? | joaotcgt | 6 | 9,095 |
07-21-2015 10:40 AM Last Post: mad.matt |
Your Attention, Please.... | oldeskewltoy | 1 | 3,803 |
07-30-2014 09:04 PM Last Post: driftmaniacae86 |
