How do you make your handbrake lockup?
01-02-2005, 10:03 PM
Hi All,this a a newbi from Denmark,
I would really like to know how you make the handbrake,so i can lock the wheel,
It seem that it´s impossible on mine,even with brand new calipers. Angry
regards from denmark,
Skassa
"""www.turbotoys.dk"""
01-02-2005, 10:39 PM
Hi Skassa Wave
Did you change the hand brake cable? They seem to get more flexible whith time.
The guys I know who uses their AE86 for rally have hydraulic hand brakes... As far as I recall it isnt too expensive and I know that you arent going to use it as a daily driver so thats not problem either Smile
[Image: AEU86 AE86 - How do you make your handbrake lockup?]
01-02-2005, 11:12 PM
handbrake ??? i thought we use normal brake and gas pedal to turn the car?
01-03-2005, 12:14 AM
Maybe handy if you could lock your wheels when it is parked Tongue
01-03-2005, 12:15 AM
mabey you should put a litre of NOS under that "handbrake" instead? THAT would make your car loose controle!
Ofcourse you would be in the ditch with a popped headgasket and a gearknob through your heart, so I advise you on changing the handbrake cable Tongue
01-03-2005, 12:28 PM
Before we all go advising you to change the cable (which is not a bad idea actually), first I would like to ask if you have tried adjusting it.
01-03-2005, 04:38 PM
and here comes Ivanhoe to save the day Smile
Hurray!
that's the sort of thinking i realy like.
not buying new items the moment a problem arise, but first check if the old ones are realy done for. Speaking of locking your rear wheels: Mine could use some adjustment as well :wink:
He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which.
01-03-2005, 04:44 PM
No one needs the handbrake just slam it in rewerse at the entrance fo the corner and you will be fine.
01-03-2005, 04:57 PM
s.bjelke Wrote:No one needs the handbrake just slam it in rewerse at the entrance fo the corner and you will be fine.
Hahahahaha! Respect!
01-03-2005, 04:58 PM
Reverse is a bit harsh: you won't be able to park you car anymore... You could easialy just put the car two gears down to get the same effect. :lol:
  Handbrake adjustment discs? DMC 8 1,984 03-10-2024 08:08 PM
Last Post: DMC
  Can you convert your 86 back too the original state? gh0st 7 3,055 04-25-2022 04:25 PM
Last Post: gh0st
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,259 08-19-2018 12:08 PM
Last Post: AlexKTM
  How would/have you rebuild your 4age? joaotcgt 6 9,087 07-21-2015 10:40 AM
  Your Attention, Please.... oldeskewltoy 1 3,803 07-30-2014 09:04 PM
Last Post: driftmaniacae86
User(s) browsing this thread: 13 Guest(s)
