How much performance gain from headers ??
11-04-2008, 09:56 PM
forgot to mention: my engine is with MAP, no cat, no O2 sensor.
SFD
11-04-2008, 10:06 PM
buy the trd engine mounts and u will skipp the clearence problem Big Grin
Don´t Think About The Past,
Live In The Present And
Dream About Tomorrow
11-04-2008, 10:08 PM
11-04-2008, 10:42 PM
I was planning on getting lowering mounts at some point. Didn't know the trd ones were also lowering. But would it be enough? They shouldn't be lowering the engine for more than 1cm, right? That would only give me the clearance required if the header fitted was just touching the floor...
SFD
11-05-2008, 01:46 AM
Depending on how much tube length you have to play with, and how
many tubes you have to bend, it may be possible to do it by heating.
Basically, the technique involves heating up a spot with a gas torch
until it is dull red, and then quenching it with water. The tube will bend
(shrink) a little at that spot.
By repeating the process several times on the same side of the tube,
the tube will begin to bend in that direction. Obviously, the further away
you can make the bend from the spot that is touching, the easier it
will be to gain clearance.
The heat will spoil your bling header pipe, but after a while the whole
pipe will go brown anyway Smile
Cheers... jondee86
11-05-2008, 01:50 AM
drako323 Wrote:forgot to mention: my engine is with MAP, no cat, no O2 sensor.
No O2 sensor = not good emissions and not good economy.
Cheers... jondee86
11-05-2008, 11:54 AM
Most European hachis didn't come with catalytic converter, so most of them don't have the lambda and/or oxygen sensor either.
[Image: AEU86 AE86 - How much performance gain from headers ??]
02-21-2009, 01:14 AM
OFFICIAL Group Buy: Custom Hytech Headers
http://www.aeu86.org/viewtopic/official-...ers/t/8291
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 20,435 05-01-2021 10:09 PM
  Headers recognition FanIsHere 2 3,082 11-23-2020 02:28 PM
Last Post: FanIsHere
Wink LHD AE86 headers and exhaust Lt86 54 64,868 05-25-2017 06:13 PM
Last Post: zenki
  weir performance email filh 2 4,698 06-14-2015 05:37 PM
  Weir Performance rear upgrade kit for AE86 heshan 5 9,025 07-22-2013 09:11 PM
Last Post: heshan
