Weir Performance rear upgrade kit for AE86
07-22-2013, 06:45 PM
Has anyone here used it?
I've put in an SR20DET into my car and as of now planning to run with the stock setup with OEM LSD. I'm really worried even a slight slip will rip the LSD apart. It'll be a crime to see that rare LSD in pieces.
Your comments would be much appreciated as I plan on getting a set down.
http://www.weirperformance.com/axlekitsc...erear.html
Cheated on my いたずらな女の子 and now I can't get enough of her..
07-22-2013, 07:54 PM
http://forums.club4ag.com/zerothread?id=51316
We are still making these kits but are out of stock on the 28mm axles as of 5/18/11. We will have more ready in about 8 weeks. Since we started building these kits we have had zero axles break, one spool stripped splines on one side due to a very bent housing but other than that it has been working well. Here is a link to Patrick Cyr first formula D event at atlanta. He is running the axle and spool kit and is really testing the parts at 340+ HP. http://www.vimeo.com/23743960 Nothing can be made indestructable but we have been happy with the results of these kits.
if my axles break which i hope they dont i think this is the best option.
07-22-2013, 08:21 PM
Thanks Ditn.
What Torque number does Patrick's car carry?
07-22-2013, 08:22 PM
I want to collect these items in Canada. Is that possible? Toronto to be exact.
07-22-2013, 09:06 PM
I think its best you contact weir performance for those answers Smile
I did a little bit of research if my axles would break since they the oem ones are not cheap and hard to find.
07-22-2013, 09:11 PM
Thanks mate.
I did actually and haven't heard from them hence I'm trying to find feedback separately until they get back to me.
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 6,095 06-23-2017 05:21 PM
Last Post: pack
  Ta60 carina steering upgrade? Allexz 15 16,304 06-01-2016 08:12 AM
Last Post: Allexz
  weir performance email filh 2 4,996 06-14-2015 05:37 PM
  Rear ae86 rear discs & pad part numbers? J-86 4 6,188 11-30-2012 06:32 PM
Last Post: J-86
  Weir-Perfomance axle question cle 2 4,606 09-06-2011 09:04 AM
