How to adjust camber on the front using standard adjustment?
06-16-2011, 03:16 AM
how do you adjust the front camber from standard? there is and eccentric nut on the lower arm which i believe might be the way but any help here!!??
:.JDMitch:. |
06-16-2011, 08:08 AM
AE86 has no eccentric's. No camber adjustment without buying either camber plates, adjustable lower control arms, or making your own custom control arms.
Andrew |
06-16-2011, 08:56 AM
Hi mates. I take the post to make a question about this. A year ago, i mount a lower springs set, about (-4cm). I noticed recently, the car has more negative camber in the right wheel than left one
![]() RCAs are made to correct this error? or the only solution is as assassin10000 says above? Thanks! ![]() ![]() |
06-16-2011, 09:40 AM
RCA's will do nothing for camber. You need
You need to look at camber with your weight in the car. Might equal left/right out a bit. A wheel to steer the front of the car A pedal to steer the rear |
06-16-2011, 10:14 AM
NoHachi Wrote:RCA's will do nothing for camber. You need Unless they´re NRCA´s they will give you a fair bit of camber. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
06-16-2011, 11:40 AM
Should have phrased that better.. They will do nothing for unequal camber left-right... Unless you use NRCA's on one side only.
06-16-2011, 02:42 PM
@ NoHachi Thats a cool idea...
![]() How much difference you got? Did you loose the bolt of the lca when you installed the lowering springs? In case you didn´t it has most likely twisted the bushing and broke it. Have seen this before on other cars... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
06-17-2011, 09:11 AM
fax0815 Wrote:Did you loose the bolt of the lca when you installed the lowering springs? Interesting point this... I have taken my (40mm) RCA's in and out a few times, and never loosened the LCA bolts. I wonder if this has done any harm ?? Maybe I should take a look ![]() Cheers... jondee86 |
06-17-2011, 10:14 AM
fax0815 Wrote:@ NoHachi Thats a cool idea... I don't know what is the LCA bolt (i'll have to check all), but the car runs OK, i don't feel any slack or knock in turns, curves or potholes. How much difference? Calculated at home: Diameter of the rims 38.5cm Difference between vertical level scale and rims: Right: 0.9cm -----> -1.33º Left: 1.2cm -----> -1.78º ![]() ![]() |
06-17-2011, 11:43 AM
Maybe the springs cause the problem (it happend to me at the past), what brand are they?
Did you check your caster adjustment? it can also cause some differnece to camber. ![]() |
Clutch Slip - Adjustment | DMC | 3 | 186 |
04-25-2025 11:29 PM Last Post: DMC |
Handbrake adjustment discs? | DMC | 8 | 2,299 |
What suspension set up are people using? | kazi | 8 | 8,732 |
07-06-2017 05:26 AM Last Post: headrush |
What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 15,764 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
Camber adjustment vs original struts | Lt86 | 9 | 9,907 |
05-07-2015 09:45 PM Last Post: zenki |
