How to adjust camber on the front using standard adjustment?
06-16-2011, 03:16 AM
how do you adjust the front camber from standard? there is and eccentric nut on the lower arm which i believe might be the way but any help here!!??
:.JDMitch:.
06-16-2011, 08:08 AM
AE86 has no eccentric's. No camber adjustment without buying either camber plates, adjustable lower control arms, or making your own custom control arms.
Andrew
06-16-2011, 08:56 AM
Hi mates. I take the post to make a question about this. A year ago, i mount a lower springs set, about (-4cm). I noticed recently, the car has more negative camber in the right wheel than left one Huh (before than lower springs all were the same).
RCAs are made to correct this error? or the only solution is as assassin10000 says above?
Thanks!
[Image: AEU86 AE86 - How to adjust camber on the...djustment?]
06-16-2011, 09:40 AM
RCA's will do nothing for camber. You need
You need to look at camber with your weight in the car. Might equal left/right out a bit.
06-16-2011, 10:14 AM
NoHachi Wrote:RCA's will do nothing for camber. You need
Unless they´re NRCA´s they will give you a fair bit of camber.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
06-16-2011, 11:40 AM
Should have phrased that better.. They will do nothing for unequal camber left-right... Unless you use NRCA's on one side only.
06-16-2011, 02:42 PM
@ NoHachi Thats a cool idea... Banging head
How much difference you got?
Did you loose the bolt of the lca when you installed the lowering springs?
In case you didn´t it has most likely twisted the bushing and broke it.
Have seen this before on other cars...
06-17-2011, 09:11 AM
fax0815 Wrote:Did you loose the bolt of the lca when you installed the lowering springs?
Interesting point this... I have taken my (40mm) RCA's in and out a few
times, and never loosened the LCA bolts. I wonder if this has done any
harm ?? Maybe I should take a look Confused
Cheers... jondee86
06-17-2011, 10:14 AM
fax0815 Wrote:@ NoHachi Thats a cool idea... Banging head
I don't know what is the LCA bolt (i'll have to check all), but the car runs OK, i don't feel any slack or knock in turns, curves or potholes.
How much difference?
Calculated at home:
Diameter of the rims 38.5cm
Difference between vertical level scale and rims:
Right: 0.9cm -----> -1.33º
Left: 1.2cm -----> -1.78º
06-17-2011, 11:43 AM
Maybe the springs cause the problem (it happend to me at the past), what brand are they?
Did you check your caster adjustment? it can also cause some differnece to camber.
  Handbrake adjustment discs? DMC 8 1,964 03-10-2024 08:08 PM
Last Post: DMC
  What suspension set up are people using? kazi 8 8,310 07-06-2017 05:26 AM
Last Post: headrush
  What is normal and low caster in Cusco camber plates?? T_AE86 9 15,290 01-07-2016 02:56 AM
Last Post: Deuce Cam
  Camber adjustment vs original struts Lt86 9 9,600 05-07-2015 09:45 PM
Last Post: zenki
  Using a different diff in an AE86 megabob 6 8,478 02-17-2015 03:37 PM
Last Post: megabob
