How to fit rear wheel studs without removing the shafts?
11-18-2010, 04:42 PM
I've read that it's possible to do it, but haven't found an explanation
Can someone please point me in the right direction? http://www.autoreverb.com - Loud automotive passion. |
11-18-2010, 09:21 PM
Push the stud in from the back and get the splines lined up.
Put a heavy flat washer over the exposed thread. Put a standard wheel nut on the stud backwards (flat side to washer). Put oil or grease on the thread and between the nut and the washer. Pull the stud into the hub by tightening the nut. Note that it is important to have studs with the correct spline diameter. Cheers... jondee86 |
11-19-2010, 10:29 PM
Thanx mate!
Mistlamps don't fit | gh0st | 1 | 2,321 |
10-14-2021 09:00 PM Last Post: banpei |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 10,553 |
Half Shafts Poblem | AlexKTM | 6 | 6,816 |
04-23-2018 04:42 PM Last Post: MIGGZFSU |
Ae86 bulk head mod to fit hydrolic clutch? | dinkers542 | 8 | 9,672 |
11-25-2014 09:21 PM Last Post: dinkers542 |
removing light switch ? (fixed) | MC_JP | 10 | 16,968 |
09-18-2014 05:16 PM Last Post: MC_JP |
