removing light switch ? (fixed)
09-15-2014, 03:12 PM (This post was last modified: 09-16-2014 11:28 PM by MC_JP.)
Hello,
my rehostat is broken and i'm wondering how can i remove the light switch without breaking my dash ? i tried pulling it, sticking a screwdriver in the hole of the button but nothing seem to work, or i'm to carefull, can someone please help Smile ?
Build your dreams.
Ford Puma 1.7 Zetec-s Daily
Toyota AE86 Levin Coupe "Jinxy"- Dreamcar
Mitsubishi sapporo - bosuzoku project
09-15-2014, 04:05 PM (This post was last modified: 09-15-2014 04:06 PM by d3nso.)
Are we talking about this switch?
[Image: AEU86 AE86 - removing light switch ? (fixed)]
Just pull on the switch until it comes off after that unscrew the rest of it Tongue
Daily Beater: Civic EG5
Work in progress Car: AE86
09-15-2014, 04:37 PM
(09-15-2014 04:05 PM)d3nso Wrote:  Are we talking about this switch?
Yeah the turning knob that let's you select the parking lights- dim lights with.
Oh i can just pull on it Big Grin ?
And well where can i find the 2 cabels to short cut the rehostat ? is it behind that nut or ?
thanks man !!
Build your dreams.
09-15-2014, 05:42 PM
If you need to shortcut reley for lights, you will find light green and red (or something-red) wire in blue connector behind this switch.
You will have to remove black shiny dash around cluster to remove switch and disconnect that connector and see wires.
09-15-2014, 05:45 PM
(09-15-2014 05:42 PM)Uzelac Wrote:  If you need to shortcut reley for lights, you will find light green and red (or something-red) wire in blue connector behind this switch.
So the whole dash needs to come out Sad ?
Build your dreams.
09-15-2014, 06:13 PM
not the whole dash just the part around the speedo:
09-15-2014, 06:40 PM
okay thanks ! i will have my work cut out for me tomorrow ^^" need to get it fixed befor this sunday
Build your dreams.
09-16-2014, 01:32 PM
something to have keep it in mind plastic is old when u removed maybe broke it very carefull
always friendly
09-16-2014, 11:28 PM
I got the dash light fixed !
Thanks D3nso for the dash manual, but you do NOT i repeat NOT need to cut the green / white- red clabla. if you do that the switch wont work.
To get it fixed you need to remove the lightswitch and shortcut the 2 white cables installed on the rehostat.
Thanks !
Build your dreams.
09-17-2014, 01:28 AM
Not cut red/green wires, just shortcut them to +12V since, that will fire reley in engine compartment.
If reley is broken, than you can shortcut wires, it will work, but that is not really clever idea... it is there for a reason Smile
  Ignition switch plug and wires Blaze0010 3 1,523 11-25-2024 12:29 PM
Last Post: Blaze0010
  Injector voltage problem [fixed] d3nso 16 21,102 04-03-2016 12:39 PM
Last Post: d3nso
  Removing front window trim zenki 7 13,903 09-07-2014 08:36 PM
  LHD W.G (West Germany) wires from dimmer & dash switch to headlight relays? Rascal21 11 16,637 07-07-2014 09:16 AM
  Removing interior plastics Jezza_hr 3 6,172 03-18-2013 11:41 PM
