Removing front window trim
09-06-2014, 03:41 PM (This post was last modified: 09-06-2014 03:41 PM by zenki.)
Anyone know how to safely remove the front window trim? The trim from the side windows was easy to remove but the front won't move. I'm afraid i'm going to break them or even worse crack my windshield.
ハチロク
[Image: AEU86 AE86 - Removing front window trim]
09-06-2014, 04:44 PM
Check the manual it's described there in detail
AE86 Levin
09-06-2014, 10:35 PM
I used small guitar strings to cut the kit for front window. Only you need be careful as the string will getting hot.
09-06-2014, 11:44 PM
Here you go...follow instructions carefully and you should succeed just fine.
09-07-2014, 12:12 AM
^^I looked at the manual and didn't see those pages, guess i missed them.
I'm not good with these fiddly jobs but they have to come off cause the car is getting 2k primered pretty soon.
ハチロク
09-07-2014, 03:57 PM
Just follow the instructions carefully and the trim should come off just fine. If I managed, so can you.
You definitely don't want to rush anything and break one of these parts because they are hard to come by.
09-07-2014, 07:57 PM
They're already off. The sideparts were attached with 3 screws each. Pulled the rubber seal away and that revealed screws. When the sides were off the top part could slide off. Alot of the clips for the top part were already broken. Atleast i got the trims off without breaking.
ハチロク
09-07-2014, 08:36 PM
The clips are not a problem, those can be found.. the trim is notoriously hard to find.. dunno if Toyota still has it in stock, probably not.
  window winder mechanism kazi 4 5,581 05-23-2018 11:00 PM
Last Post: kazi
  removing light switch ? (fixed) MC_JP 10 18,135 09-18-2014 05:16 PM
Last Post: MC_JP
  rear window defroster lines zenki 3 5,906 11-15-2013 02:58 PM
  Removing interior plastics Jezza_hr 3 5,925 03-18-2013 11:41 PM
  Trim levels? Serencebey 17 25,855 11-20-2012 09:24 PM
