How to install seat harness
02-05-2007, 05:41 PM
Where do I mount studs for harnesses that go beside the seat?
02-05-2007, 06:48 PM
you already have two threaded holes from the original seat harnes... One on the right on the reef and the other one on the B post (column)... You just need those ankers... O-ringed thingys to screw in there... You can buy them in Lučko... going on stara Karlovachka after the school on the left... all sort of metal stuff
SNO-MO-BIRU project started- CHIRO |
02-05-2007, 06:51 PM
Thnx mrgud, you have pm (regarding struts&sole)
02-05-2007, 07:23 PM
Under rear seat you have bolts for stock rear seat harness...
Even better is rear strut bar, if you have one. Pic that better explaines... Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
02-05-2007, 08:03 PM
meshin Wrote:Under rear seat you have bolts for stock rear seat harness... strut bar is ideal... This is too much harnes angle Mesh... You are risking with this... check Appendix J FIA... you will see why... Althou this is better than the ones I saw on some cars... SNO-MO-BIRU project started- CHIRO |
02-05-2007, 08:48 PM
How would you go about it without having to rip out your rear seats?
02-06-2007, 01:35 PM
2 mrgud: this is the best I can do in my car for now. Waiting rear strut bar, then it would be on it.
2 TRUENO><ONEURT: my friend screwed the harness like this on picture, but put something like holder (screwed in) little higher so the harness was going right between the crack in rear seats (between horizontal and vertical joint of the rear seat, if you know what I mean). Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
02-06-2007, 03:59 PM
Get a harness bar. It's the best way to mount them.
Peter Diaz http://www.shiftgearclothing.com http://www.ectoyotas.com/forum/ http://www.facebook.com/elfatherae86 |
02-06-2007, 08:03 PM
tomstwincam Wrote:Get a harness bar. It's the best way to mount them. +1 I've never been to confident running the harness down to the rear seat belt anchor points. They're just too low for my peace of mind. Also most rear strut tower bars are not designed with harness attachment in mind. I've been staying away from harnesses until I can have a harness bar built or possibly even a cage. |
02-06-2007, 10:45 PM
Can't you mount them right behind the front seat?
Id need the rear seats for transport of friends |
Bucket seat prices | gh0st | 5 | 2,348 |
01-23-2022 11:44 PM Last Post: AlexKTM |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 9,546 |
01-17-2020 08:04 PM Last Post: Project D |
Rear Seat Belt Question | sleepercivic | 5 | 9,675 |
06-29-2017 09:30 PM Last Post: banpei |
CD player install. | kazi | 8 | 8,572 |
02-21-2017 11:57 AM Last Post: banpei |
Foam-ectomy on OEM Seat | mad.matt | 2 | 3,854 |
02-17-2017 12:22 AM Last Post: mad.matt |
