How to replace the steering column UJ?
05-13-2022, 08:42 PM
[Image: AEU86 AE86 - How to replace the steering column UJ?]But I see no circlip or split washers…. I’m getting some fasteners zinc plated and hoped to get this done too…. Any suggestions? Thanks
05-14-2022, 01:46 PM
The U/J is steaked in the yoke. You will have to grind the steaking out before pushing out the U/J. And "CAREFULLY" re-steak around the inside diameter after assembly. I lot a polished stainless-steel replacement joint from Flaming Rivers, for less than 50% what Toyota wanted for a replacement joint. The only difference was a set-screw lock Vs a pinch bolt.
05-14-2022, 04:56 PM
You can also spot weld the new joint caps in place.. being carefull to cool them quickly so you dont cook the grease too much.
05-14-2022, 06:55 PM (This post was last modified: 05-14-2022 06:57 PM by Mylesmck.)
Thanks Dave W, I cut it off in the end. Cleaned the bores and filed off the stakes on one side of each piece. The UJ was €20 delivered and I’m getting a bucket of bolts etc. zinc plated so I’ll send the empty yoke off with them
(05-14-2022 04:56 PM)Ivan141 Wrote:  You can also spot weld the new joint caps in place.. being carefull to cool them quickly so you dont cook the grease too much.
Cheers Ivan, I might try that or try staking them with a hammer and punch
05-14-2022, 07:40 PM
FWIW, I just used a punch.. odds are this joint wont come loose easily.. its not spinning at prop shaft speeds after all.
  Click in steering column? DJexor 2 1,418 07-17-2023 08:26 PM
Last Post: totta Crolla
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,319 07-31-2019 11:28 AM
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 45,209 10-02-2014 06:07 PM
  Steering column weight savings? 4000GT 4 5,718 09-20-2012 08:40 PM
Last Post: 4000GT
  Adjustable steering column 4000GT 6 8,941 07-12-2012 08:15 AM
Last Post: 4000GT
