How to replace the steering column UJ?
05-13-2022, 08:42 PM
05-14-2022, 01:46 PM
The U/J is steaked in the yoke. You will have to grind the steaking out before pushing out the U/J. And "CAREFULLY" re-steak around the inside diameter after assembly. I lot a polished stainless-steel replacement joint from Flaming Rivers, for less than 50% what Toyota wanted for a replacement joint. The only difference was a set-screw lock Vs a pinch bolt.
05-14-2022, 04:56 PM
You can also spot weld the new joint caps in place.. being carefull to cool them quickly so you dont cook the grease too much.
05-14-2022, 06:55 PM
(This post was last modified: 05-14-2022 06:57 PM by Mylesmck.)
Thanks Dave W, I cut it off in the end. Cleaned the bores and filed off the stakes on one side of each piece. The UJ was €20 delivered and I’m getting a bucket of bolts etc. zinc plated so I’ll send the empty yoke off with them
(05-14-2022 04:56 PM)Ivan141 Wrote: You can also spot weld the new joint caps in place.. being carefull to cool them quickly so you dont cook the grease too much. Cheers Ivan, I might try that or try staking them with a hammer and punch |
05-14-2022, 07:40 PM
FWIW, I just used a punch.. odds are this joint wont come loose easily.. its not spinning at prop shaft speeds after all.
Click in steering column? | DJexor | 2 | 1,390 |
07-17-2023 08:26 PM Last Post: totta Crolla |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 7,279 |
Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 45,098 |
Steering column weight savings? | 4000GT | 4 | 5,693 |
09-20-2012 08:40 PM Last Post: 4000GT |
Adjustable steering column | 4000GT | 6 | 8,893 |
07-12-2012 08:15 AM Last Post: 4000GT |
User(s) browsing this thread:
