Hydraulic Clutch
11-15-2008, 06:21 PM
Hydraulic Clutch
Hi everyone, Im new to this forum, and have just purchased my first ae86. It is a 1985 Corolla GTS 4A-GE, and there are a few minor problems, one of which I was hoping you guys could help me with. The clutch has absolutely no resistance until it is about an inch or so off the floor, and catches extremely low. My local mechanic says it is probably a hydraulic clutch issue, but do our cars have hydraulic clutches? Either way Im open to any help and ideas, thanks.
11-15-2008, 09:05 PM
Hydraulic Clutch
Yep, the 4AGE has a hydraulic clutch.
The problem you describe sounds like your hydraulic system has air in it (due to low level of fluid). Best try to flush the system like you would flush a break system: one person in the car pumping on the pedal and one bleeding on the nipple.
[Image: AEU86 AE86 - Hydraulic Clutch]
11-15-2008, 10:19 PM
Hydraulic Clutch
I had the same problem (clutch engaging very close to the floor) and
it was caused by the slave cylinder being partly seized. Particles of
rust had jammed the piston so that it could not move freely in the
cylinder. The fluid was like rusty water Undecided
You should take the slave cylinder off and dismantle it to inspect the
cylinder bore. If it is badly rusted, you should replace it with a new
one, and then bleed the system with fresh fluid.
Cheers... jondee86
11-15-2008, 11:45 PM
Hydraulic Clutch
i had the same prob changed the slave cylinder but now there is a leak somewhere on mine as there is less fluid in the master cylinder during time Sad
11-16-2008, 03:33 AM
Hydraulic Clutch
Clutch master leaks on the drivers side of the firewall... runs down and
goes under the carpet Confused Most likely it will be wet under the pedals and
the fluid will be attacking the paint.
Fitting a new master cylinder is a bi*ch, as the nuts are high up under the
dash, and you need to be upside down to reach them !!! Take some
patience pills before you start the job Smile
Cheers... jondee86
11-16-2008, 03:08 PM
Hydraulic Clutch
great to hear that is is an easy job Wink I have a new master and slave clutch cylinder waiting.. Big Grin
Gtsi-R
"Trust me, I was an engineer"
11-17-2008, 09:56 PM
Hydraulic Clutch
yeah probs i havent really checked tbh it doesnt seem wet under the carpets but like i said i havent really checked properly but its most like the master cylinder thats knackered
05-09-2009, 03:21 AM
Hydraulic Clutch
today i dont have clutch and brakes, still have oil in the tank and have oil in the pedals
AE86 owner
  Hydraulic handbrake with stock rear brakes Dino86 11 16,170 07-11-2014 08:33 PM
Last Post: Dino86
  Clutch Master Cylinder and Clutch Slave Cylinder fitment? christsang7 2 5,245 07-01-2009 07:48 AM
Last Post: jondee86
  Hydraulic handbrake 205t16 15 32,838 10-16-2006 07:15 PM
  Problem: Soft clutch pedal - no clutch activation dreja 5 7,548 02-09-2006 11:27 PM
Last Post: Denmark
