Hydraulic Clutch
11-15-2008, 06:21 PM
Hydraulic Clutch
Hi everyone, Im new to this forum, and have just purchased my first ae86. It is a 1985 Corolla GTS 4A-GE, and there are a few minor problems, one of which I was hoping you guys could help me with. The clutch has absolutely no resistance until it is about an inch or so off the floor, and catches extremely low. My local mechanic says it is probably a hydraulic clutch issue, but do our cars have hydraulic clutches? Either way Im open to any help and ideas, thanks.
11-15-2008, 09:05 PM
Hydraulic Clutch
Yep, the 4AGE has a hydraulic clutch.
The problem you describe sounds like your hydraulic system has air in it (due to low level of fluid). Best try to flush the system like you would flush a break system: one person in the car pumping on the pedal and one bleeding on the nipple. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
11-15-2008, 10:19 PM
Hydraulic Clutch
I had the same problem (clutch engaging very close to the floor) and
it was caused by the slave cylinder being partly seized. Particles of rust had jammed the piston so that it could not move freely in the cylinder. The fluid was like rusty water You should take the slave cylinder off and dismantle it to inspect the cylinder bore. If it is badly rusted, you should replace it with a new one, and then bleed the system with fresh fluid. Cheers... jondee86 |
11-15-2008, 11:45 PM
Hydraulic Clutch
i had the same prob changed the slave cylinder but now there is a leak somewhere on mine as there is less fluid in the master cylinder during time
11-16-2008, 03:33 AM
Hydraulic Clutch
Clutch master leaks on the drivers side of the firewall... runs down and
goes under the carpet Most likely it will be wet under the pedals and the fluid will be attacking the paint. Fitting a new master cylinder is a bi*ch, as the nuts are high up under the dash, and you need to be upside down to reach them !!! Take some patience pills before you start the job Cheers... jondee86 |
11-16-2008, 03:08 PM
Hydraulic Clutch
great to hear that is is an easy job I have a new master and slave clutch cylinder waiting..
Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
11-17-2008, 09:56 PM
Hydraulic Clutch
yeah probs i havent really checked tbh it doesnt seem wet under the carpets but like i said i havent really checked properly but its most like the master cylinder thats knackered
05-09-2009, 03:21 AM
Hydraulic Clutch
today i dont have clutch and brakes, still have oil in the tank and have oil in the pedals
I'm so JDM I put everything sideways. AE86 owner |
Hydraulic handbrake with stock rear brakes | Dino86 | 11 | 15,557 |
07-11-2014 08:33 PM Last Post: Dino86 |
Clutch Master Cylinder and Clutch Slave Cylinder fitment? | christsang7 | 2 | 5,111 |
07-01-2009 07:48 AM Last Post: jondee86 |
Hydraulic handbrake | 205t16 | 15 | 32,048 |
10-16-2006 07:15 PM Last Post: Ivan141 |
Problem: Soft clutch pedal - no clutch activation | dreja | 5 | 7,226 |
02-09-2006 11:27 PM Last Post: Denmark |
