I need rods 40mm crank journal, and 20mm wrist pin!!!!
10-31-2010, 08:45 PM
Search connecting rods :40mm crank journal, and 20mm wrist pin, for mi 4age too puting 4agze pistons.
I have looking in ebay but nothing. |
10-31-2010, 11:14 PM
Absolutely normal because only 2 types of conrods are available:
18/40mm 20/42mm If you have 40mm crank (bluetop) and if you want to use pistons with 20mm wrist pin you have to change your conrods AND your crankshaft. |
11-01-2010, 07:25 AM
you can find correct rods on gen2(if remember right or 3) 4afe it has 20mm wristpin and 40mm big end.. here many use on "big port"4ag as turbo. 4agze pistons to smaller crank...
11-02-2010, 12:10 AM
I have the rods from 4agze pistons too(20mm pin and 42 mm crank journal). I nieh the crankshaft but kan not found it.
11-04-2010, 06:57 AM
Project D Wrote:Absolutely normal because only 2 types of conrods are available: http://www.aeu86.org/viewtopic/ae86/p/131906#131906 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 18,301 |
08-16-2018 01:36 AM Last Post: Bean |
crank 6 bolt flywheel | DJexor | 5 | 8,420 |
12-05-2016 08:21 AM Last Post: d3nso |
4ac crank on 4age! | Ghetto | 7 | 10,562 |
12-05-2014 10:42 PM Last Post: Uzelac |
Crank pulley without harmonic damper | Jan Pedersen | 21 | 24,581 |
05-21-2014 09:50 AM Last Post: Bean |
Crank seal | TheGerman | 8 | 11,214 |
04-12-2014 09:36 AM Last Post: Apsogos |
