ITB's/Stand Alone ECU?
06-07-2007, 12:25 AM
I fiited a set of 20v ITB's and Stand alone ECU on my 4AGE. Got the car running, baldly, link below. The car drove over to the riolling road. It won't take any throttle load, it just dies! Anyone any ideas? The car idles/drives perfect on maybe 1/5 throtte! After that not well at all.
http://www.youtube.com/watch?v=XCS-Zokqh-E Cheers Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
06-07-2007, 09:14 AM
Is map sensor connected?
AE86 GTS '84 Red Top |
06-07-2007, 09:16 AM
Lean mixture ?
Do you have any logfiles ? |
06-07-2007, 07:18 PM
I think it is too lean aswell, the guy who has the rolling road, thinks it's ignition. I Have a map sensor conected, but I don't really know the software on the ECU, I have only used for ignition in the past, but when starting with all unknowns, it's hard to tell. I will keep you posted if there is any progress.
06-07-2007, 07:25 PM
euhm it should not fire at the intake ............. i would rather have it running to reach than to lean set ignition at 10 bdc there should be maps for the ecu you bought google to see if there is one for a standard 4age
06-08-2007, 03:13 PM
check your ignition maps and your map sensor...
this 1/5 throtle is fine if not pushed fast? SNO-MO-BIRU project started- CHIRO |
06-14-2007, 08:57 PM
The 1/5 throttle is fine if you push slow and steady. The car actually drives very nice and can do 50-60mph. Any more throttle than that it just dies. The guy with the rolling road is taking a look at it now to see if he can find what is wrong. Will keep you posted when it comes back, hopefully!
06-15-2007, 09:37 AM
Sounds like it is over-advanced. Try knocking your timing back a bit
and see if that makes a difference. If not, just think of it as a speed governor to keep you safe ![]() 50-60 mph ?? Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
08-02-2007, 10:37 PM
Finally got the car sorted, fitted two amplifiers to drive the injectors, problem solved. I will be picking the car up on sat. The guy ran it on the rollers and said is is making the same sort of power as standard. but his rolling was broken and needs re-calibrated. He thinks it is going alot better. I will get my brother to drive my Ford Mondeo ST220 home with me, and I can see how much faster it is. Think it need a good run on the roller, maybe in a few weeks for fine tuning.
08-29-2007, 09:56 AM
What is the score?
Is it any better? Did you measure AFR? SNO-MO-BIRU project started- CHIRO |
ITB convert need standalone ECU | izanagi | 2 | 7,132 |
04-07-2016 11:24 PM Last Post: izanagi |
stand alone ECU but i want to keep my rev clock | williep12 | 28 | 31,342 |
08-25-2010 02:26 PM Last Post: thanhngo |
Quads Throttle Intake (ITB) on Stock JDM ECU. | kool mints | 21 | 22,488 |
06-24-2009 01:28 AM Last Post: kool mints |
Power - 4AGE ITB's and Stand alone ECU? | byd1380 | 10 | 14,900 |
02-27-2009 12:45 AM Last Post: Elitetech |
ITB + freedom ecu | peter | 5 | 12,054 |
08-20-2008 07:09 PM Last Post: Project D |
