stand alone ECU but i want to keep my rev clock
02-18-2010, 04:51 PM
Hi All.
I'm putting ITB's on my AE86 with a stand alone ECU but i want to keep my rev clock Sad So can someone please tell me what wire is used to Transmit the signal back to the clock. Is it one of the wires going to the dissy or what . Thanks all Thumbs up!
Drive it like your late for mass and god is your passenger / don’t just bend the rules rule the bends fun ant in a straights!!
02-18-2010, 08:42 PM
without knowing, but using common sense.
The signal should originale off your coil.
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
[Image: AEU86 AE86 - stand alone ECU but i want ... rev clock]
02-18-2010, 09:12 PM
williep12 Wrote:Hi All.
Check the documentation for your ECU. On the one I am using, you can
configure one of the unused ignition outputs as a tacho output.
Cheers... jondee86
02-18-2010, 11:37 PM
Ordinarily your tach signal should be coming from the negative terminal on your ignition coil. If your sticking with original ignition you should be fine as long as you dont remove the wire.
As Jondee said, most aftermarket ECU's can output a tach signal as well..
02-19-2010, 08:53 PM
thanks lads ye the ECU wire isn,t the problem but what wire do i tag it to Banging head
02-19-2010, 09:37 PM
williep12 Wrote:thanks lads ye the ECU wire isn,t the problem but what
Have a read here....
http://www.aeu86.org/viewtopic/map-harne...ewall+plug
Cheers... jondee86
02-21-2010, 03:11 PM
im using a standalone ecu, you will have to use your standard ecu 2 so that you will be able to use your rev clock,
wont affect you at all
02-21-2010, 10:51 PM
Think about it for a while... if your not changing ignition parts, and the tach wire of the original is coming from the negative coil terminal, then you dont need to change a thing!
You dont need you standard ecu because it is not supplying the tach signal.
02-22-2010, 09:20 PM
Ivan141 Wrote:Think about it for a while... if your not changing ignition parts, and the tach wire of the original is coming from the negative coil terminal, then you dont need to change a thing!
well i had toi use standard ecu
02-22-2010, 09:31 PM
Why? Dumb question
  Engine starts/revs but no idle GenkiMotors 17 12,648 11-20-2021 04:12 AM
Last Post: GenkiMotors
  Carb conversion but what is this and how ? Allexz 5 10,261 05-24-2016 08:48 AM
Last Post: Allexz
  Raising the rev limit on stock ECU fax0815 2 12,877 08-31-2015 02:04 PM
Last Post: gon
  4age 16v oem ecu rev limiter research ditn 18 33,634 06-22-2015 08:02 AM
Last Post: ditn
  getting new sparkplugs, or keep away ? MC_JP 5 8,063 09-19-2014 11:35 PM
Last Post: Project D
