ITB's on 16v
10-17-2007, 09:25 PM
ITB's on 16v
hello i have accuired itb's of a 20v ST and apart from the electronic aspect can anyone rccomend a adaptor. My main concern is a feed for the brakebooster pipe and the vacuum source. does anyone have an idea?
10-17-2007, 09:35 PM
ITB's on 16v
Technotoytuning sell a manifold adapter, the vacuum issue is usually solved by running tubes from every runner into a single vacuum buffer (reservoir), and run the brake booster and map sensor from that. Check Ian's s2000 hachi project thread for the vacuum reservoir thingy and setup.
10-17-2007, 10:59 PM
ITB's on 16v
Brake booster...If you want to keep it, do it the way Ivan mentioned, but in your position I wouldn't use it...Think about it, if you ever drive a car without brake booster (servo), you will see that you will have much better feeling.
10-23-2007, 11:58 AM
ITB's on 16v
Suggest you look at using a separate tapping (or tappings) for the
brake booster. Otherwise you will be sending the ECU a "false" reading each time you use the brakes. Probably not a biggie unless you are using the "heel and toe" driving technique Deleting the brake booster will most likely mean re-engineering the braking system. Disc brakes are not self-energising, so if you just delete the booster without changing anything else, the pedal effort will be high !!! Try driving with the vacuum hose disconnected if you want to get an idea of how high... but allow extra braking distance !!!! Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-02-2007, 11:18 PM
ITB's on 16v
jondee86 Wrote:Suggest you look at using a separate tapping (or tappings) for the I donĀ“t really think this would be an issue, as you brake booster stores a certain amount of vacuum during driving, plus you have a one way valve in your vacuum hose. and, the booster is not using a lot of air, thus not really affecting your vacuum readings... |
How to install 20V ITB on 16V head | Mr.komp | 7 | 11,819 |
12-28-2015 05:35 PM Last Post: pack |
Brake booster and ITB's on 16v | harkes | 17 | 28,905 |
08-01-2012 03:59 PM Last Post: Bean |
Manifold Vacuum on 16V with ITB's... | jondee86 | 7 | 8,524 |
04-15-2010 10:57 AM Last Post: jondee86 |
ITB on 16v adapter | D.O | 4 | 5,334 |
11-16-2008 04:03 AM Last Post: jondee86 |
New ITB -> 16v adapters | harkes | 8 | 7,278 |
09-22-2008 11:42 AM Last Post: Project D |
