Manifold Vacuum on 16V with ITB's...
04-11-2010, 10:22 PM
On my 16V smallport I have Silvertop ITB's mounted on a custom
fabricated tube manifold. Vacuum is sampled from all four inlet tubes
by way of small bore hoses (same size as OEM MAP sensor hoses).
At idle I am only getting 30 kPa of vacuum (70 kPa absolute pressure).
This seems a bit low, so has anyone got ITB idle vacuum readings to
compare ?? I'm going to check the reading from the brake booster
connection, as that comes from a larger set of manifold tappings. Just
to make sure the small hoses, to and from the map sensor vacuum
tank, are not causing a restriction.
Cheers... jondee86
04-11-2010, 11:30 PM
I have ST ITB's with T3 intake manifold and 68/70 kPa absolute pressure at idle.
I'm using Megasquirt with Alpha-n because under load pressure drop near to 100 kPa
Here's a video how idle
http://www.youtube.com/watch?v=aTmtrCVMm8c
and normal driving
http://www.youtube.com/watch?v=7v6eSI1G898
04-12-2010, 03:05 AM
Interesting !! I knew that ITB's didn't have much vacuum, and it's nice
to know that someone else has about the same result. I'm running on
a TPS only fuel map at the moment, but I would like to be able to get
some sort of manifold pressure fuel map working, so I can run try out
a TPS x MAP blend. That way I can use the Predictive MAP throttle pump
feature on my Adaptronic Smile
Your engine looks very tidy... wish I had space to use that style of filter.
Cheers... jondee86
04-12-2010, 07:43 AM
can you give me the tps only map ? i am going to setup a greddy e-manage ultimate with itbs too ... :wink:
04-12-2010, 10:15 AM
alimonos Wrote:can you give me the tps only map ? i am going to setup a greddy
The map I have is just some line values I put in to make a startup map.
It was set up for VE tuning, with the first line 35%VE @ 0% TPS, rising
incrementally to 90%VE @ 65% TPS. Everything above 65% TPS is @
90%VE, and all lines have the same value from 0 to 8000 rpm.
The engine runs on this map with good A/F ratios, but I haven't tuned
the idle properly yet. The self-tune function has completed a few cells,
and they are not far off the numbers I started with. I really don't think
the map would be of any help with what you are trying to do. Better
for you to use a WBO2 gauge and adjust your settings until you get a
good A/F ratio.
Cheers... jondee86
04-12-2010, 03:13 PM
jondee86 Wrote:...
This one it's a bit smaller
04-15-2010, 10:57 AM
Looks as so I have a cam timing problem Blush Just moved the cams
around a bit, and now I have 45 kPa of vacuum. I'm going to degree the
cams and then try a few different settings. I'd be happy if I could get
around 55-60 kPa at idle Smile
Cheers... jondee86
  Smallport inlet manifold totta Crolla 6 3,712 01-17-2022 05:14 PM
  How to install 20V ITB on 16V head Mr.komp 7 12,229 12-28-2015 05:35 PM
Last Post: pack
  US-spec vacuum hard lines LordTD 2 5,227 04-27-2015 07:18 PM
Last Post: Project D
  4age blue top from MR2 same intake manifold? dinkers542 8 10,961 11-02-2014 05:24 PM
Last Post: ditn
  VALVE ASSY, VACUUM SWITCHING, what's this for ? Uzelac 10 15,153 11-22-2013 10:40 PM
Last Post: jondee86
