ITB + turbo?
01-31-2008, 01:02 PM
ITB + turbo?
Hi,
currently I have a turbo 4AGE - smallport 16V, with 8.9:1 GZE pistons, reversed stock 4age smallport intake manifold and GT2560R turbo.
What is your opinion about adding 20V ITB to that turbo engine?
Cheers.
AE86 GTS '84 Red Top
01-31-2008, 02:24 PM
ITB + turbo?
since you run a turbo, I believe that you will not get more prffit out of ITB.. since there is always turbo preasure..
ITB will help on normal aspired engines..
or am I wrong..
:offtopic:
do you have a project topic ot the 4agte ?
sounds interesting!!
cheers,
Roel
01-31-2008, 02:50 PM
ITB + turbo?
It will definitely have better throttle response... Smile
JapanPower
UoP Racing website
UoP Racing videos
01-31-2008, 07:23 PM
ITB + turbo?
Take a look at the Nissan GTiR..it has a similar setup.
There are probably practical problems to overcome.
Different turbo anti-surge setup (now sudden very high pressure in intake manifold instead of vacuum before turbo).
Probably have to run a stiffer return spring on the butterflies.
Fueling needs to go via a MAF or vacuum reference lines in the runners "after" the butterflies (this last option might be tricky..don't know how stable the signal will be).
01-31-2008, 09:31 PM
ITB + turbo?
I guess it would be best to use TPS for load reference up to 80kpa (absolute pressure) and MAP sensor from 80 to 220kpa (where I plan to stop).
I would use ST or BT ITBs and they already have vacuum tank giving pretty stable MAP signal. I had the chance to map Silvertop with MSextra and have some experience in that area.
01-31-2008, 10:02 PM
ITB + turbo?
i can give you an email adress of a friend of mine. He's putting together a citroen Mi16 + ITB + turbo and he did alot of research on the subject. He is making his own ITBs in solidworks to be cut on cnc machine and god i don't know what else.
  whats the crack with 16v turbo? kazi 5 6,578 08-02-2017 12:15 AM
Last Post: kazi
  Bluetop on turbo leon205gti 7 8,337 09-20-2016 09:17 PM
Last Post: leon205gti
  can i just slam a oem turbo on it ? MC_JP 3 6,276 12-17-2014 11:04 PM
  4age stock bigport on turbo leon205gti 8 17,068 01-17-2014 01:02 PM
  4AGTE turbo manifold questions daveskatesallday 3 5,174 08-13-2013 07:38 PM
Last Post: daveskatesallday
