ITBs with turbo?
07-13-2009, 08:37 AM
ITBs with turbo?
Is it possible to run a turbo WITHOUT fuel injection on a 4AGE? Is it worth it?
Anyways, I'm building a 4AGE. Is there a list with the best parts I can choose from Etc?
07-13-2009, 11:49 AM
ITBs with turbo?
you can't run ITB's without EFI. THan you are running carbs. It is possible but its almost useless as the intake is forged induction instead of normal air induction.
So you could but its not easy. You should make the IC connect to the intake then but you will need to be running a closed air circuit on your intake then.
07-13-2009, 12:23 PM
ITBs with turbo?
Woops. I'm dumb Dumb question
I meant to say can you run a turbo with CARBS?
07-13-2009, 12:38 PM
ITBs with turbo?
Search google for blow through turbo..
07-13-2009, 12:56 PM
ITBs with turbo?
See the maserati bi-turbo.
It has one twin-weber in a closed box wich was fed by the twin turbo's.
[Image: AEU86 AE86 - ITBs with turbo?]
Rokuichi Power !!
_________________________________________
Toyota Starlet KP61 2.0 vtec
07-13-2009, 01:47 PM
ITBs with turbo?
But why build an engine to potentially blow it up due to poor fueling? Seems like a poor cost cutting exercise in a time where complete EFI setups cost half of what you pay for a decent set of secondhand carbs.
07-14-2009, 02:01 AM
ITBs with turbo?
Can you link me to a complete EFI setup please?
07-14-2009, 07:06 AM
ITBs with turbo?
http://www.diyautotune.com/
or:
http://www.bs-autotune.nl/content/view/66/76/
in Dutch, but basically a prebuilt MS2 with all the options using SMD technology ( a lot better then soldering stuff yourself).
edit: english link: http://www.k-data.org/index.php?lang=en
07-14-2009, 09:05 AM
ITBs with turbo?
Alright, looks like I'm gonna have to read up on this, I don't know exactly what I'm looking at.
It IS a stand a lone engine management system.. but I don't know EXACTLY what I need.
Dumb question
Sorry guys. I'm a bit new to the AE86 world, although I do know what megasquirt is, but the only thing I've heard of it used for it Methanol injection etc.
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,840 02-10-2020 06:39 PM
Last Post: Power_uP
  whats the crack with 16v turbo? kazi 5 6,539 08-02-2017 12:15 AM
Last Post: kazi
  Bluetop on turbo leon205gti 7 8,274 09-20-2016 09:17 PM
Last Post: leon205gti
  can i just slam a oem turbo on it ? MC_JP 3 6,251 12-17-2014 11:04 PM
  4age stock bigport on turbo leon205gti 8 16,995 01-17-2014 01:02 PM
